Author Topic: Frame Brackets  (Read 6561 times)
Offline crazedhick3
Frame Brackets
« on: January 01, 2008, 11:55:09 am »
Anyone changed any bracketry on frames?  I have a rear spring perch bracket that needs changing while I still have the frame down to "bare bones".  Also, what are you replacing the rivets with?  Just bolts or bolts and weld?  Are aftermarket pieces of good quality?  Thanks
Offline 80stepsideguy
Re: Frame Brackets
« Reply #1 on: January 01, 2008, 12:37:25 pm »
I changed the front leaf spring hangars on my stepside.It came with grade 8 bolts in the kit so i just put them on with a little dab or loc tite and torqued them down to the reccomended specs.I also replaced the rear crossmember in the very back , the 1 i had had a big bend in it and i bought 1 from a member here.Ground off the rivets, put the new 1 on and did the same, grade 8 bolts and loc tite and torqued the bolts down to 50 ft lbs.But thats about it .
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline 123 pugsy
Re: Frame Brackets
« Reply #2 on: January 01, 2008, 06:25:54 pm »
Use loctite and you're good. Do not
weld the nut to the bolt as it could get brittle and break easy.
Pugsy
76 C10 LWB
TPI 350
Offline 1976Scottsdale
Re: Frame Brackets
« Reply #3 on: January 01, 2008, 09:45:30 pm »
I used 7/16" grade 8 bolts when I did perches on a friend's  78 K-10.  All I had to do once the rivets were out was use a cordless drill with a 7/16 bit and buzz it throught all the holes, bolts went in really tight and it all lined up nicely.  Same here on torque, about 50-60 ft/lb is all I did then I had him go test it and I retorqued them again.  Same thing I'm gonna do to my 76 3/4 ton 4x4.
Re: Frame Brackets
« Reply #4 on: January 02, 2008, 09:15:56 am »
Grade 8 bolts and a little locktite..
Re: Frame Brackets
« Reply #5 on: January 02, 2008, 11:00:56 am »
I too have use grade 8 bolts, but I used lock nuts along with lock washers and locktite.
Offline xtremjeepn
Re: Frame Brackets
« Reply #6 on: January 02, 2008, 11:45:29 am »
4x4 guys do it all the time to flip the rear shackle over. As mentioned before just use good grade 8 and locktite.
http://diy4x.com/suspension.htm
http://www.offroaddesign.com/catalog/shacklekit.htm
Cole
Restomod Crew Cab Short box on 37"s
