Author Topic: Take out a leaf in front?  (Read 4465 times)
Offline qboy
« on: January 01, 2008, 06:57:55 pm »
I've already taken 2 leaf springs out of each side of the rear which had 6 per side and the truck rides much better.   Front of truck is still very stiff.   I've got two leaf springs per side up front.   Can I remove one on each side?
1975 K15 GMC 1/2 ton SWB 4x4 383 (stroked 350), turbo 350 tranny
Re: Take out a leaf in front?
« Reply #1 on: January 02, 2008, 04:05:49 am »
I wouldnt! I would be putting the two rear leaves back in if it were mine.
« Last Edit: January 02, 2008, 10:45:18 am by Blazin »
Offline Redneckchevy
    • Photo Bucket
« Reply #2 on: January 02, 2008, 08:44:16 am »
Same here. These trucks wear meant to work not play.So to play you will probably want to upgrade.
« Reply #3 on: January 02, 2008, 09:11:21 am »
NEGATIVE!  Unless you want it to sag to the ground.  If it is riding rough in the front what shocks do you have?
Offline qboy
« Reply #4 on: January 02, 2008, 12:27:37 pm »
Just put on new Rancho 5151 shocks.    They seem a little long although they're the ones called for.   I might just leave it alone for now.    I wonder if anyone makes a coil spring conversion kit.
