Author Topic: cheap sound deadening for cab floor?  (Read 9959 times)
Offline locdogg
« on: January 05, 2008, 12:56:58 pm »
I just got my bench seat recovered and have my vinyl cab flooring out right now.  I'm looking to make the cab as quiet as possible as cheap as I can.  Any suggestions?
Has anyone used herculiner or a bedliner product on the cab floor?
I've thought about that white asphalt roofing stuff, has anyone used anything like that?
Is this gonna stink up the cab when it gets 90-100 degrees?  :-\
I was thinking of putting down a layer of bedliner/white asphalt roofing stuff, then some carpet pad I have laying around, then plastic sheeting (to make sure water doesn't get to the pad where it would soak it up, maybe some more bedliner/white asphalf stuff then the old vinyl flooring
Offline 86 chevy silverado
Re: cheap sound deadening for cab floor?
« Reply #1 on: January 05, 2008, 04:54:51 pm »
 , Sound deadener/heatshield kits for floor $44.95
http://www. competitor.com/index.htm
Offline werewolfx13
« Reply #2 on: January 05, 2008, 06:32:23 pm »
Some sound comp guys use "peel n seal" from home depot/lowes when they're on a budget, some have problems with odor and some dont. In the cab, I'd bet you would. A bed liner would help a little, but don't expect a miracle. Cheapest route that would still work REALLY well, would be 1-3 coats of e-dead v3..its sold by the gallon and works wonders when applied properly. IIRC its only like $45-$55 per gallon.
Chris
'83 Chevy c10 Silverado SWB
Offline Mr79C10
  • My 79 C-10 Project
    • My 79 C10 Project
« Reply #3 on: January 05, 2008, 10:50:41 pm »
The order lasts maybe a day. I did my cab. Not bad but man,,, sure does deaden the sound!
*House of Friends
Offline FlatBlack77
« Reply #4 on: January 06, 2008, 02:29:24 pm »
news paper ;)
Offline SUX2BU99
« Reply #5 on: January 07, 2008, 02:56:32 pm »
I did my cab floor in 1/2" carpet underlay. Get it at any Home Depot. Made a nicely noticeable difference. Cost was less than $20.
Offline autorepr
« Reply #6 on: January 28, 2008, 04:18:34 pm »
What about actual asphalt shingles? Maybe roll roofing? It's just like the stuff I've seen bonded to floors from the factory. It's already cured so it wouldn't stink, it would insulate from heat and sound. And it would be CHEAP!!!! Paint or coat the floor with whatever you want, lay in the shingle material, go with some thin carpet insulation over it and then your carpet. Maybe?
