Author Topic: Engine Swap questions  (Read 3993 times)
Offline 85MudMonster
« on: January 09, 2008, 01:08:35 pm »
Hi. Okay, I want to eventually change out my worn 305 engine. And I've decided against a high power 350 swap like everyone else does. I want to stick the 5.3L Displacemant on Demand engine from the 2005+ GM trucks/SUVs. I like the power and the fuel consuption as well. What I want to know, is will the 5.3L bolt up to a 4L60E or a 4L80E, and how much will I have to modify the engine and trans mounts to make those fit. I know that the 460LE is about 1/2" to 1" longer than the TH350 I have so will I need new driveshafts as well? Also, what transfer case will work with this combo, right now I've got a NP208, which I know is a weak case, and chain driven but I like the gearing in it. That's all I can think of for now. It'd be nice having a truck with 310HP and 20MPG.
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Re: Engine Swap questions
« Reply #1 on: January 09, 2008, 03:26:26 pm »
The engine will fit along with the trans.  5.3L come in front of 4L60E, and will bolt to 4L80E's.   I would get the complete running gear including the t-case from a donor.  You will need the wiring harness (complete) and ECM for DOD.  A 4L60E is the same as a 700R4(4L60) so you just have to move the crossmember back.
Check my 73-87chevytrucks.com project thread on how to get a LS motor in one of these...
« Reply #2 on: January 09, 2008, 08:27:57 pm »
what about transmission lenght difference? Will I need a shorter dravishaft out back and a longer one up front? or do they have some play in them? I think the front one does but I'm not sure about the back one....
Dan
« Reply #3 on: January 09, 2008, 11:12:00 pm »
You will need new driveshafts if you are currently running a TH350...
