Author Topic: th400 replacement  (Read 4560 times)
Offline 75??? franken-trunk
th400 replacement
« on: January 13, 2008, 10:19:49 pm »
i was wondering on a tranny swap, th400 to th400. the one in my friends 91 1 ton duelly went out on him... the truck has a tbi 454 in it... we found a th400 out of a car like a olds delta 88 or something along those line line (big car) it may have had a small block not sure though... would that one fit are they the same length and whats not there are both 2x4 vehicals any info???
Jack'em High
Fat chicks can't climb
Offline Fordeatinz71
  • 78k miles and counting
Re: th400 replacement
« Reply #1 on: January 14, 2008, 12:55:28 am »
noooooo...there were two different bellhousings on these...one was a B-O-P-C bellhousing (Buick, Olds, Pontiac and Cadillac) and would ONLY fit Buick, Olds, Pontiac and Cadillac motors and the other was for Chevrolet/GMC (which used Chevy engines).  you have to know what MOTOR that tranny came from...if it's anything besides a Chevrolet you CAN'T use it...
Offline werewolfx13
« Reply #2 on: January 14, 2008, 01:07:07 am »
A bellhousing adaptor plate would remedy that problem. They CAN be used, but its a bit more work.
Chris
'83 Chevy c10 Silverado SWB
« Reply #3 on: January 14, 2008, 01:30:38 am »
yea, i guess you could use an adapter...but just bolting it straight up won't happen.  as far as length...i think it would be the same...not positive though...
Offline 2500HD-454
« Reply #4 on: January 14, 2008, 02:24:38 am »
I've done a swap like this. All you need is a bellhousing adapter. BUT you need to measure the length of both trannys from bellhousing to the end of the output shaft. Several of the passenger car trannys had short shaft trannys. You probably have a long. The difference is the tailshaft length. MEASURE. Everything else should work fine.
Offline werewolfx13
« Reply #5 on: January 14, 2008, 04:18:14 pm »
I'm not sure about a delta 88, but my dad's '78 cadillac coupe deville has a th400 with a long tail shaft. Just wish the 425 wasn't such an expensive engine to build for power AND still maintain the AC compressor.
« Last Edit: January 14, 2008, 04:20:32 pm by werewolfx13 »
Chris
Offline xtremjeepn
« Reply #6 on: January 14, 2008, 10:07:19 pm »
Go to NAPA and buy a rebuild kit. They are pretty cheap.  Probably just needs new clutches anyway.  Rebuilding a TH400 is pretty simple if you have ANY mechanical skills.
Cole
Restomod Crew Cab Short box on 37"s
