Author Topic: pcv  (Read 11168 times)
Offline Dragon
Re: pcv
« Reply #15 on: January 23, 2008, 02:26:12 am »
My M/T's look like the should just simply knock out (already had enough plugs removed when I got them), but to be safe I would use a hole saw....   I'm sure someone else may chime in as to what you could do....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline Redneckchevy
    • Photo Bucket
Re: pcv
« Reply #16 on: January 23, 2008, 02:32:53 am »
if u dont have a knock out I would only use a hole saw if the area is flat ..And only cut the hole as big as u need to fit the grommet ..And mask the area off..And make sure you use oil when cutting the hole and let the saw do the work so u dont dent and warp Ur valve cover. and make sure the cover is off the engine..And make sure when ur done u clean it all up so it will be free of any metal flakes
« Last Edit: January 23, 2008, 02:34:48 am by Redneckchevy »
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Re: pcv
« Reply #17 on: January 23, 2008, 04:16:51 am »
don't forget to try to add a baffel to the inside of the valve cover to keep oil from sucking into that pcv
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
