Body, Glass & Paint
primer wont sand
Topic: primer wont sand (Read 27300 times)
hogwild
primer wont sand
January 27, 2008, 12:04:45 am »
primed my truck last weekend with endura intermix 3to 1 epoxy primer, went to sand it today and it wont sand , it just plugs up paper and makes gouges.it doesnt matter what grit it use either. what now ?. reprime over it with different primer?
1986 sb 406 ci
2003 mud buggy 1300 hp 528
if my wife askes it was only fifteen bucks
Redneckchevy
Re: primer wont sand
January 27, 2008, 12:06:23 am »
sounds like u might of mixed it wrong......I wouldnt repaint over it...Or the new primer will be floating...im pretty sure the bad stuff will have to come off....
hogwild
January 27, 2008, 12:14:26 am »
wana buy a truck? . how am i to get it of wont sand. some kind of stripper?
1986 sb 406 ci
JRConnieK10
January 27, 2008, 12:20:02 am »
Maybe try to wet sand an area first.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Redneckchevy
January 27, 2008, 12:24:07 am »
Was it mixed to specs? or eye balled?
hogwild
January 27, 2008, 12:25:52 am »
we mixed it dead on to specs , 3 to 1
1986 sb 406 ci
HAULIN IT
January 27, 2008, 12:29:26 am »
Hogwild, I'm familiar with paints/primers, ect. (I own a body shop) however I'm not familiar with the Endura products. Epoxy products come in many different make-ups for different jobs. Some are used primarily for adhesion to bare metal, these do not sand very well usually, others can be epoxy based filler type primer, which should sand fairly well after drying. Did you get a product data sheet on this primer when you bought it? It may not be intended for the way you are using it or as mentioned, maybe something is mixed wrong (incompatible products, ect.) Don't panic yet! Read up on how it is described on the directions & post, We will try to help. Lorne
Redneckchevy
January 27, 2008, 12:30:30 am »
see im thinking its soft and wet...Epoxy primer should not gouge that easy...Its epoxy it should be hard......Maybe u should call the pepole that make it...maybe they would have better advice then to strip it down...
hogwild
January 27, 2008, 12:35:42 am »
went to endura site , and it says intermix 3-1 primer is for sand blasted steel , says nothing about sanding it . i dont have instructions, primer was left overs that i had from painting a trailer.
1986 sb 406 ci
Redneckchevy
January 27, 2008, 12:48:35 am »
Could it of gone bad?
hogwild
January 27, 2008, 01:00:22 am »
its only 1 month old , and its suposed to be good for one year after opening, maybe it needs to cure longer , but i thaugt a week should be lots of time
1986 sb 406 ci
Redneckchevy
January 27, 2008, 01:01:41 am »
ok i got ya...But what temp are u curing it at??
hogwild
Reply #12 on:
January 27, 2008, 01:15:27 am »
24HRS AT 20 than it went out side at about -15 for 4 days then back in shop for 2 days at 15-20 c
1986 sb 406 ci
zieg85
Reply #13 on:
January 27, 2008, 07:37:50 am »
Epoxies stop curing at 50 degrees F. They all do.
Blazin
Blazin new trails!
Reply #14 on:
January 27, 2008, 07:51:06 am »
In my experience if the sander speed is to high epoxies tend to smear, instead of sand.
I agree some epoxy primers are not meant to be sanded. They are meant to be topcoated within a few hours of application.
You might have to strip it off with heavy paper or stripper.
Body, Glass & Paint
primer wont sand
