Author Topic: My 78 k10 restoration  (Read 38008 times)
Offline hotrod24
Re: My 78 k10 restoration
« Reply #15 on: October 23, 2009, 05:44:51 pm »
lol yea we did, my bad well i have been grinding all the old rusty hangers rivets but the back rear spring hangers, i want to save and i did not want to mess them up with the grinder. i could probably get them being very careful and work slow but the front ones are good and a grinder wont fit i just want to take them off because rust might be behind them but i dont know.
1978 pontiac grand prix...
Offline Donut
« Reply #16 on: October 23, 2009, 09:15:45 pm »
Whew!  I thought I was getting more forgetful with age (my wife says I am  ::))
If you have access to an oxy/act torch (and have moderate skill) you can "wash" the heads off the rivets, and not damage the hanger.  I don't remember if you can gain access from the backside. (Grind them off the back, and drive them through)
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline crazedhick3
« Reply #17 on: October 25, 2009, 12:47:59 am »
Take a die grinder with a cutting wheel. cut an "x" in the head of the rivet.  then knock the head of with an air chisel.  lots of noise and time consuming but works pretty good.  i probably did thirty rivets like that on my frame.
Offline thirsty
    • Suitor's Garage
« Reply #18 on: October 25, 2009, 10:05:19 am »
I just recently stripped 3 frames of all the brackets to do a 2wd to 4wd conversion. I used a torch to burn the heads off then a air chisel with a punch end in it. I tried to only use the torch on the side that I was not using but sometimes I had to cut the head off on the side I was using, in that case if the rivet didn't come out for me then I used a grinder to remove the rest.
Offline hotrod24
« Reply #19 on: October 26, 2009, 05:11:34 pm »
 thanks, i am using all the brackets and one rear hanger, all the rest is junk and they get the grinder i will try the x thing i dont have a torch right now. i could get one from lowes or some where that might help
Offline hotrod24
« Reply #20 on: October 29, 2009, 05:14:35 pm »
ok the x thing worked thanks alot
« Last Edit: November 03, 2009, 09:09:41 pm by hotrod24 »
« Reply #21 on: October 31, 2009, 07:04:27 pm »
years ago I had to remove all the cab mounts from a frame to install on another. I just used a cold chisel with a good edge on it and a big hammer.
Offline hotrod24
« Reply #22 on: November 09, 2009, 11:48:36 am »
ok got some more cut off wheels and rust wheel for my grinder, oh and a propane tank so i am ready lol
pics to come
Offline hotrod24
« Reply #23 on: November 13, 2009, 05:40:09 pm »
well the propane did not work, as well as i thought it would i got to get these rivets out i got the heads off its just that they are stuck.
« Last Edit: November 13, 2009, 07:17:27 pm by hotrod24 »
Offline thirsty
    • Suitor's Garage
« Reply #24 on: November 13, 2009, 06:02:48 pm »
Make sure that you have removed every bit of the head and keep pounding. You will get it.
Offline hotrod24
« Reply #25 on: November 13, 2009, 07:38:24 pm »
yea i have been cutting x in them and taking my air hammer and knocking the head off them, i was doing good untill i got to the middle cross member. now i cannot get the rivets out of the frame. well i can but the cross member i am having heck of a time, i think i am going to have to take the bottom of the crossmember off so i can get the rivets out.
Offline hotrod24
« Reply #26 on: April 07, 2010, 05:49:23 pm »
ok well this post and project has been over for sometime but have not got a chance to explain back in the winter my project was not going any where and money was hrad so i looked at the one thing that i was not using at the time and the olny thing i had to get some cash and first things first all I had was a frame, a cab, and 2 axles so there was not much there for a project, but I know a lot of people start from scratch.  Anyway, since my block was cracked it just pee'd me off more than ever so that put me down on my project some.  and then come needing some cash, so I took all the metal around my house and scrapped it and things got worse so I scrapped the axels and what ever else I could find.  I just sold some parts to a good friend of mine, that helped me out alot!  but since I am out of the hole now, I am trying to find me a 67-72, going for a new body style.  Chris would you please take this post off and thanks for all your help and advice that was given to me.  I will have another 73-87, just right now I am looking in to another body style because of my project.
thanks
« Last Edit: April 07, 2010, 08:39:06 pm by Captkaos »
