Author Topic: '82 Cruise Control  (Read 7704 times)
Offline shippman
  • New Users
'82 Cruise Control
« on: February 13, 2008, 09:21:09 am »
My '82 3/4 Ton pickup is factory equipped with cruise control (non-electronic).  This model does not allow the "tap" feature to increase or decrease speed on the fly.  I would like to upgrade to this feature.
Does anyone have any information on the availablility of a non-electronic cruise module with the "tap" feature for this truck; and if so where to get said unit besides the bone-yard?
If not, has anyone ever done a conversion to the later electronic versions (factory) in an early truck like this? Any articles or clues?
Any help on this would be appreciated.
Mike
Online Captkaos
Re: '82 Cruise Control
« Reply #1 on: February 13, 2008, 10:06:16 am »
The later models (83-up if I remember correctly) used the VSS on the back of the speedo to handle the cruise control.
Not sure what you mean by a tap feature, but the factory cruise on these weren't that great.
Offline Dragon
« Reply #2 on: February 13, 2008, 05:26:50 pm »
Factory Non-Electric Cruise Systems are junk, as most cases the diaphram usually dries out/Tears/usually develops a large hole with time... Seems like a lot of Companies out there try to rape you, when it comes time to replace the Old Diaphram as well :o
As Capt said, later models used a VSS connected to the rear of the Speedo, and the Majority of the Quality Aftermarkets do as well!
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline eventhorizon66
« Reply #3 on: February 13, 2008, 09:24:13 pm »
My 85's was vacuum controlled from the factory.  Always acted quirky, combine that with an anemic 305 and 1550 rpm @ 70 mph, it was worthless.  But it did have the "tap" feature you are referring to, only to increase speed though (in 2 mph increments).  Most newer cars allowed to decrease speed the same way, but these trucks never did.  I disconnected it since I never use cruise control, not even on cross-country trips.
'85 C10 SWB 350 700R4 TKO600
Offline Uno99
« Reply #4 on: February 14, 2008, 09:48:28 am »
My 81 came wit it. I only use it if Im above 60 other with it is not consistant.
1981 GMC High Sierra SBO 350 LT Headers 2.5" Tru Duals, H-pipe, Flowmaster SUPER 44 Mufflers 2000 TCI Stall PICS http://www.cardomain.com/ride/2410355
