Author Topic: '77 K30 Crew Cab Longterm Restomod  (Read 47420 times)
Offline Mr. Lee K30
  • It’s been awhile...
Re: '77 K30 Crew Cab Longterm Restomod
« Reply #15 on: August 08, 2008, 08:25:22 pm »
Well its been awhile so...
Was driving the Crew Cab around for a couple of weeks until it kept running hot and pinging like crazy.  I found multiple vacuum leaks on the motor in just about every place and decided to park it.  Then my coworker wanted to sell his '77 with a rebuilt 454 (with only 1500 miles) for the price of building up the 400... so I decided why not  ;D
In the next couple of weeks I will pull the sb400 from the Crew Cab, prep the engine bay and then pull the 454 from the other rig and drop it in the Crew Cab.  Gonna also try to do a good write-up on going from small-block to big-block with pics  ;)
Oh... and sometime I will get the wiring figured out for the dash cluster swap going from non-tach to tach cluster from a '76?
1978 C10 Longbed 2WD
250 I6 & 3spd Saginaw
Soon to swap in TBI 305 and 700R4 from ‘88 C1500 2WD
Offline Prong
« Reply #16 on: August 09, 2008, 06:29:53 am »
You need a 77 cluster because the number of warning lights and printed circuit traces are different between the 76 and 77.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline 06gsxrman1000
« Reply #17 on: August 11, 2008, 12:04:37 pm »
i love the 3+3's
Three may keep a secret, if two of them are dead.
-ben franklin
Offline Mr. Lee K30
« Reply #18 on: August 12, 2008, 11:21:56 pm »
Thanks for the info!
« Last Edit: August 06, 2009, 10:50:49 pm by Mr. Lee K30 »
Offline Mr. Lee K30
« Reply #19 on: August 29, 2008, 01:10:26 am »
This weekend...
ENGINE SWAP!!!  ;D
« Last Edit: August 06, 2009, 10:53:45 pm by Mr. Lee K30 »
Offline BigHemi353
  • Diesel Enthusiast
« Reply #20 on: February 15, 2009, 03:00:33 pm »
update?  ;D
Offline Mr. Lee K30
« Reply #21 on: February 18, 2009, 10:37:02 am »
The engine swap is... still in progress  :-[
I took on a side project for a couple of months which haulted progress and now I'm finally getting back on the ball.  Currently working on painting up stuff on the motor and getting the engine bay cleaned up and painted.  I FINALLY found the correct bucket seat brackets for my Hi-Back seats and got them mounted up in the cab.  Also debating on whether to loose the NP203 transfer case in favor or a NP205.  Will post up some pics later this week  :)
« Reply #22 on: February 18, 2009, 11:52:48 am »
I thought you disappeared.  Where's the pics :D?
Offline Mr. Lee K30
« Reply #23 on: August 06, 2009, 11:25:03 pm »
Okay the ball is still rollin' on this beast and I fixed all the missing pics in previous posts.  The engine swap is almost complete and I have plenty of pics for your viewing pleasure :)
Painted the Firewall black
Out came the Big Block
Offline Mr. Lee K30
« Reply #24 on: August 06, 2009, 11:34:30 pm »
Decided to tear off the front sheetmetal as it all was pretty rusted and made putting in the 454 much easier
Here's the Super Beefy Motor Mounts from DIY4x4
Prepping the 454 and in it goes...
Painting brackets and other misc stuff:
Offline Mr. Lee K30
« Reply #25 on: August 06, 2009, 11:55:08 pm »
POR-15'd the bottom of the Core Support... then painted
Custom Stainless Steel Sleeves for the front body bushings
Complete 454 ready to go!
I spent HOURS cleaning and painting stuff and really liking it so far.  Still have lots to do including the rest of the sheetmetal, electric fuel pump install and gas tank cleaning, the rest of the body bushings and more...
« Last Edit: August 07, 2009, 02:11:45 am by Mr. Lee K30 »
Offline cowboy63645
« Reply #26 on: August 07, 2009, 12:25:17 pm »
Looks great!!  What are you using to paint all of your brackets and such?  Also, I noticed in a earlier post, you were thining of swapping transer case's...they sell a part time kit for the 203, then all you would need is new lockouts for your front axle and your done!!
Offline 79K20
« Reply #27 on: August 07, 2009, 02:42:00 pm »
Lookin Good! Keep it up!
Offline 78Scottsdale
  • Light Without Heat
« Reply #28 on: August 07, 2009, 11:02:41 pm »
What size rims were on that truck before you put those Cragars on it, and what size are those Cragars?  I'm so glad I seen that picture, because I didn't think the cragar center bore was large enough to fit over that full floating axle.
-The Garage-
1987 Pontiac Grand Prix 305 V8 - 67k Orig. Miles
-Looking To Buy-
1978 Chevy Scottsdale K20, 350 V8, All Stock, Rust Free Frame, New Paint, Beautiful Truck.
Offline Mr. Lee K30
« Reply #29 on: August 11, 2009, 07:38:21 pm »
I've been using mostly Dupli-color engine paint and Rustoleum primer paint.  The 203 has already been converted over to part-time and have decided to stick with using it.  The wheels are Les Schwab brand (maybe made by Cragar???) but yeah they fit over the front & back hubs with some room for center caps.
Recent work includes dropping the driver side gas tank and cleaned it up.  Got the wrong sending unit (outlets point the opposite direction) so now I gotta order the correct one.  Later I will have pics of the gas tank install plus mounting and plumbing the new electric fuel pump and filter on the frame...
