Author Topic: I need help  (Read 3919 times)
Offline fallguy841
I need help
« on: February 16, 2008, 08:07:00 pm »
 I,ve recently purchased a 80-87 short bed k10 with a new crate lt1 engine and a rebuilt t350 tranny and both axles werew rebuilt with possi . Also new sheet metal 8yrs ago and the past 3yrs it was parked in a barn to rot.It runs ok but starting to have problems now ,first the rear lights went out and found bad wiring from last owner but it is all working good now and properly wired.
   Now my horn does not work found  2 horns on the rad support and tested them ok ,the fuse is good ,is there a relay for the horn ?
Offline ccz145a
Re: I need help
« Reply #1 on: February 16, 2008, 08:16:52 pm »
yep, mine's bolted to the emergency brake bracket.
Offline monte85
Re: I need help
« Reply #2 on: February 17, 2008, 11:27:39 pm »
the gm service manual for my 87 shows it taped to the harness above the fuse block. but i think mine is in the convenience center next to the steering column.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
