Author Topic: front sway bar  (Read 7027 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
front sway bar
« on: February 17, 2008, 03:18:58 pm »
will a front sway bar from a 3/4 ton 2wd truck bolt right up to a 1/2 truck? Thanks
Offline 80stepsideguy
Re: front sway bar
« Reply #1 on: February 17, 2008, 03:22:43 pm »
If its 2wd it should
thanks
paty
1998 Chevy 1500 S/B 2wd
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: front sway bar
« Reply #2 on: February 17, 2008, 03:32:49 pm »
yes both are 2wd, thanks
Re: front sway bar
« Reply #3 on: February 17, 2008, 03:41:08 pm »
shouldnt see any problems on fitment/
thanks
pat
Offline 86 chevy silverado
Re: front sway bar
« Reply #4 on: February 17, 2008, 05:16:19 pm »
The one on the 3/4 ton might even be bigger diameter, check that for the right bushings, otherwise should bolt up.
Re: front sway bar
« Reply #5 on: February 17, 2008, 08:38:13 pm »
You definately have to use the 3/4 ton bushings, and it really improves the handling
