Author Topic: spacer  (Read 6225 times)
Offline mikewb
spacer
« on: February 20, 2008, 12:23:46 pm »
anybody use a phenolic carb spacer. do they make difference.
Offline Redneckchevy
    • Photo Bucket
Re: spacer
« Reply #1 on: February 20, 2008, 12:32:53 pm »
Well iv seen on horsepower tv ...They used a spacer and put it on a dyno and it showed that it added power....So why not...The way it works makes since it lifts your carb up higher and lets for a bigger gulp of air/fuel...
Offline HAULIN IT
Re: spacer
« Reply #2 on: February 20, 2008, 02:25:59 pm »
Mike, In most cases a spacer will help increase torque & horsepower. This is because it gives additional room to straighten the path for the air to go instead of  crashing into the floor of the intake. The non-metallic ones also help keeping a little heat off of the throttle plate. It is a simple install, so I feel it is worth trying it, however don't think you are going to gain 30 HP from this, on one case this may have happened, but that is probably with a  $130 spacer & after ALOT of testing. Gains of a few ft. lbs & hp is more like it. One thing I would advise is if you have an intake with 4 round holes (stock type), I would only use a  4 hole spacer. Have Fun, Lorne
Offline werewolfx13
Re: spacer
« Reply #3 on: February 20, 2008, 05:40:56 pm »
They do increase power a little bit IF they're matched to your carb/intake like Lorne said..4 hole intake/carb, get a 4 hole spacer. I've got a few 1" spacers for a predator carb, since a spacer is required for good torque with one..
Chris
'83 Chevy c10 Silverado SWB
Offline joesgarage71
  • Wrench
Re: spacer
« Reply #4 on: February 21, 2008, 10:30:34 am »
 Using phenolic helps to reduce carb temp, It helps to insulate the carb. If you have a 4 hole intake use a 4 hole spacer, Open intake open spacer, most spacer tests I have seen, the improvement was at the higher RPM using a 1"-2" spacer.
 Be sure to test the clearance between the spacer and throttle blades, don't need to have her stuck open on start up or on your test drive.
« Last Edit: February 21, 2008, 10:34:23 am by joesgarage71 »
Offline mikewb
Re: spacer
« Reply #5 on: February 21, 2008, 01:25:16 pm »
which one better 1" or 2"
Offline 86 chevy silverado
Re: spacer
« Reply #6 on: February 22, 2008, 05:38:17 pm »
Horse power gains are at higher RPM and more beneficial on higher horse power/ RPM motors. You may lose some off idle/ low rpm throttle response, and probably not notice any power gain depending on the performance level of your engine. If any try the 1" spacer.
