Author Topic: LWB to SWB Conversion  (Read 332460 times)
Re: LWB to SWB Conversion
« Reply #120 on: March 21, 2008, 04:15:01 pm »
Today I filled in all the stake pocket holes.
notched the bed for the roll pan
Here it is in place
It's gettin there...
« Last Edit: July 25, 2017, 03:56:51 pm by VileZambonie »
Offline DnStClr
« Reply #121 on: March 21, 2008, 06:29:41 pm »
What do you do to fill in the stake pocket holes? Is there a plug or a piece that you fit over the hole and weld?
Don
87 Chevy Silverado
Offline JJSZABO
« Reply #122 on: March 21, 2008, 08:45:49 pm »
Looking good Vile  ;D
Did you run into anything unusual in putting on the rear roll pan?  I still have to do this.  I know about the bed notching.
Jeff
86 Chevy C-10
350, TH400
« Reply #123 on: March 21, 2008, 11:20:18 pm »
Just notching the bed if you plan on running a roll pan with the license plate box aside from that, I would weld it in as a permanent piece.
For the stake pockets I actually used the piece I notched the bed floor with and filled the pockets using that metal. I'll post more pix later.
Offline CR10
« Reply #124 on: March 24, 2008, 10:25:24 pm »
Hey Vile, I know a lot of people on this forum told ya how much they are loving your truck, but I gotta say, that´s nothing, I´m saying I really really love your truck, it´s just great, I bought an 80 short, a couple of years back, started work on it , till I found the chassis was cracked and bend in so many spots, that I could´n believe how in the world was running, I was actually thinking of junk my truck, cause I thought it would take a lot of years and money to put that thing straight; BUT untill I read this whole process of yours, you really inspired me, I´m saying for real!
I´m obviously replacing the chassis....
By the way, you used 3¨flowmasters, but never said what kind, are those super 44´s?
`79 C10 LWB
« Reply #125 on: March 25, 2008, 04:51:30 am »
Thanks! I appreciate all the positive reinforcement! This forum has helped motivate me also!
The flowmasters I put on there are the old big block 2 chambers. I don't think they sell them anymore. ???
For your truck if the frame is tweaked real bad it might not be a bad idea to look for a junker with a nice frame and just swap everything over. These trucks are getting more scarce and a lot of them are getting crushed so start looking now and good luck with your build!
« Reply #126 on: March 26, 2008, 08:35:07 pm »
OK so after lots of debating I think I'm gonna start cutting....
« Last Edit: July 25, 2017, 03:57:40 pm by VileZambonie »
Offline eventhorizon66
« Reply #127 on: March 26, 2008, 11:14:08 pm »
Gonna look good I think.  But if you haven't already started cutting, may I suggest that you lower the position of the lights maybe an inch or so and see what you think.
'85 C10 SWB 350 700R4 TKO600
« Reply #128 on: March 27, 2008, 03:08:34 pm »
I agree that it would look the best if measured from the top ledge to the bottom ledge and offset it to the middle, BUT, there is a body ledge that would have to be addressed that sinks in (where the rollpan is)
Offline 82chevy
« Reply #129 on: March 27, 2008, 05:25:36 pm »
nice vile...thats gunna be sick
Offline HAULIN IT
« Reply #130 on: March 27, 2008, 10:36:48 pm »
Vile, Just my opinion. I feel those lights are a little long for the area you have to work with. The body line above & below the original light hole seems to dictate the length of the light. Won't they have to be recessed quite a bit in the middle to be flush at the top edge? It's only steel, nothing that can't be changed with a welder if you don't like it at some point. I have seen long thin lights like that (Caddy?) adapted on vehicles before & do like the style, I'm just not sure with the curves of the body. Just my two cents, Carry on! Lorne
« Reply #131 on: March 28, 2008, 07:33:11 am »
The tail lights can really go any further down or they would be so far sunken in and the bedside would be so hacked up there'd never be a turning back point. The lights sit recessed behind the buckets themselves and have to actually fit inside the panel etc so that's basically as low as they'll go. I saw a guy with an orange truck like this the other day and I really liked the look of it. Different but slick. I think I'm gonna do it.
Offline 123 pugsy
« Reply #132 on: March 28, 2008, 03:57:03 pm »
 Go for it! You've got good taste with mods so start cutting. ;)
Pugsy
76 C10 LWB
TPI 350
« Reply #133 on: March 29, 2008, 09:35:13 pm »
Ok I started cutting
crappy pix
« Last Edit: July 25, 2017, 04:03:53 pm by VileZambonie »
Offline 82chevy
« Reply #134 on: March 29, 2008, 09:49:29 pm »
wow looks very nice so far...keep it up man lol
