General Discussion
gauges....Again...
4
Topic: gauges....Again... (Read 37989 times)
JJSZABO
Re: gauges....Again...
Reply #45 on:
March 26, 2008, 07:49:46 pm »
Good job Red
Jeff
86 Chevy C-10
350, TH400
Reply #46 on:
March 26, 2008, 08:16:31 pm »
everything is working?
Redneckchevy
Reply #47 on:
March 26, 2008, 08:19:17 pm »
Not the seat belt....But i found the wire from the brake light...It was on the junction box on the cross member....A dark brow wire...It was a ground wire coming of a sensor...But i had to run a new Wire from my gas tank cause I found the wire...But the wire was funky looking...Even tho it worked i wanted to replace it...So i slid the bed back and replaced it....But yeat all the lights work.....And the gauges
Redneckchevy
Reply #48 on:
March 28, 2008, 10:12:39 am »
ok...SO every thing was going good...Got the oil leak fixed and I bought the steel plates for my frame repair.....SO...Went to start my truck...Click Click nothing...Ok...So i put it on charge for one hour...Checked it with my tester put a load on it....Looks fine...Checked the acid...Thats fine...Started that truck up Checked the alternator...Thats fine..Checked my starter...Lil weak....Shut truck down...Went to start it...Click Click..Battery is dead.....Battery is brand new...Battery has a Cut off switch...So no battery drain...Could my alternator regluator be bad??
Reply #49 on:
March 28, 2008, 02:26:13 pm »
the battery passed the load test? Sounds like a dead cell ...
Redneckchevy
Reply #50 on:
March 28, 2008, 02:32:23 pm »
yea...Im not even going to take it back...I should just drop in a optima...And say good buy to this Valucraft
Reply #51 on:
March 28, 2008, 02:33:28 pm »
If it's new just return it! Optima's are nice but a lil pricey. You can just get a good AGM battery for less.
Redneckchevy
Reply #52 on:
March 28, 2008, 02:34:30 pm »
I should....Its only got 550 cold cranking amps....And autozone is o so sure thats the right one
Reply #53 on:
March 28, 2008, 02:44:53 pm »
They probably just gave you the cheap group 75 battery. Get the 34DT-DLG Duralast. That's a better autozone battery
Redneckchevy
Reply #54 on:
March 28, 2008, 06:55:40 pm »
Thanks vile...I bought the duralast gold 1000Cranking amps
4
General Discussion
gauges....Again...
