Author Topic: front bed panel swap  (Read 4737 times)
Offline 73resto
« on: March 01, 2008, 11:34:46 am »
Hi guys new to this forum. Im swapping front bed panel from 74 to 73 but having problems getting it off after taking bolts out. Do you have to take side panels off to get front bed panel off? I searched but couldnt find thread thanks for responses.
Offline HAULIN IT
Re: front bed panel swap
« Reply #1 on: March 01, 2008, 12:02:49 pm »
Resto, I feel the best way is to loosen both sides from the wheelwells foreward, you will need help pulling/pushing them apart or use a port-a-power/jack or something on the inside. Gently push/pull them apart, remove the old one, install the new one & put the bolts back in. Good luck on your project, Lorne
Offline 73resto
« Reply #2 on: March 01, 2008, 12:09:28 pm »
thanks for the quick response i am in the middle of it. james
