Author Topic: Vacuum: The Basics  (Read 4226 times)
Offline VeeTwin60
Vacuum: The Basics
« on: March 03, 2008, 07:12:00 pm »
Hey Guys,
I would like to make sure my vacuum lines are hooked up properly.  Just the basics - no smog/emission equipment.
1986 C/10
350 Engine/350 Trans
Holley Model 4150 Double Pumper
If you could give me a "this goes to this", or a diagram (not the one under the hood - like I said, no smog equipment).  Just the simple basics.
Thanks
1986 C-10 1/2 TON 2WD SWB
Offline Redneckchevy
    • Photo Bucket
Re: Vacuum: The Basics
« Reply #1 on: March 03, 2008, 07:14:35 pm »
Well i pluged all mine up but u do want the vacuum advance...PVC...And brake booster...Thats all i run...And a vacuum gauge
Ok brake booster goes to the large port on back of carb....and  pvc can go to larg one on the side.....And Ur vacuum advance goes to a source that only gets vacuum when u lay on the gas..On a holey its next to the float bowl ..now i only had one large port so i had to use a T fitting for my pcv and brake booster works well i have no probs with stoping
« Last Edit: March 03, 2008, 07:18:51 pm by Redneckchevy »
Offline ccz145a
« Reply #2 on: March 04, 2008, 08:31:36 am »
Of course you need the vac line going to the hvac vac resivoir (round ball on pass side in engine compartment) that operates the various air handler doors. Comes off a tee fitting on the manifold.
I have only owned AC equiped trucks, don't know if heater-only had this or not.
Offline Cowboy_Customs
« Reply #3 on: March 04, 2008, 04:25:00 pm »
Nope, no Vac. ball on the non A/C trucks.
As redneck says, there is a port on the carb by the float bowl for the Advance. Its been so long sence Ive tinkered with a Carb I have forgot how the brakes get their Vacuum. Plus the fact most of my trucks have Hydroboost......  ;D
Dream Truck:
1991 GMC Crewcab Dually Western Hauler conversion 454TBI 4L80E 19.5's
http://community.webshots.com/user/Cowboy_Customs
