Author Topic: Painting POR-15  (Read 8783 times)
Offline 75 C20
Painting POR-15
« on: March 05, 2008, 08:29:37 pm »
i was wondering if anyone has had luck with sanding, priming, sanding, and painting sheetmetal that has had por-15 put on it.   could i get it to look good if i primered it and sanded it enough?? primer/paint will stick to por 15 good wont it?
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline d stroud
    • Our Cars
Re: Painting POR-15
« Reply #1 on: March 05, 2008, 08:50:50 pm »
I've never used on on a panel that was gonna be painted.
But, it is supposed to be nearly impossible to get anything to stick to it without using their "Tie-coat" primer.
Seems to me though if you got it scuffed good, a good epoxy primer should stick to it.  I would try it on a small  section first.
Give the epoxy time to cure then see if you can wipe it off with thinner.
Our Family Muscle Site
Yeah, Its got a Hemi...Just sucked one down the carb a few blocks back.
Offline 86 chevy silverado
Re: Painting POR-15
« Reply #2 on: March 05, 2008, 09:39:01 pm »
Assuming the POR that is on there now is bonded well to the metal, you are able to sand and epoxy prime then paint as normal, if that answers your question. If you question the bond of the POR, then maybe consider sand blasting.
Re: Painting POR-15
« Reply #3 on: March 06, 2008, 07:04:43 am »
As long as you topcoat POR 15 or Chassis Saver ( same type of product half the price ) within the cure period paint will stick to it. I don't remember off hand but I believe it is under 8 hours. A large portion of the roof on my car has Chassis Saver brushed on, then several hours later high build urethane primer, then Omni single stage acrylic enamel on it.
Re: Painting POR-15
« Reply #4 on: March 06, 2008, 07:28:52 am »
Is my statement incorrect? You cannot prime over the POR with epoxy, if so why? Just for my knowledge. I was told previously that this could be done properly.
Re: Painting POR-15
« Reply #5 on: March 06, 2008, 07:41:35 am »
I am sure you can. I was only saying that if you do it within the cure window you don't need to scuff it. I have sanded older POR 15 with 180 grit and painted over it too. It was a bear to sand well though. Ate up allot of paper as it is hard.
« Last Edit: March 06, 2008, 09:01:56 am by Blazin »
Re: Painting POR-15
« Reply #6 on: March 06, 2008, 07:59:25 am »
That I understand! I wanted to make sure I wasn't giving out false info. I couldn't understand why it would be a problem. My body shop buddy blasted and coated a old hood from a '40s truck that was pitted with rust brushed on a couple coats of POR, sanded and recoated and it now has a bullet proof coating and is smooth again. The before and after was night and day.
Re: Painting POR-15
« Reply #7 on: March 06, 2008, 11:16:08 am »
I generally paint it on and then wait for it to get tacky and then top coat it with whatever (on my frame)  It has held up so far.
Offline d stroud
    • Our Cars
Re: Painting POR-15
« Reply #8 on: March 06, 2008, 09:12:12 pm »
Thats probably the best way.
Unless the POR is already there.  Then the epoxy should work if scuffed.
BTW,  IF you guys have never tried it, Eastwoods Rust Encapsulator is a much better product.  I've used both on different old chevy a-bodys and the Eastwood stuff is much, much better.  Plus, you can paint right over it.
