Author Topic: brakes dragging  (Read 17813 times)
Offline the_legend_1981
brakes dragging
« on: March 06, 2008, 03:06:00 pm »
78 c10 manual brakes are dragging on drivers side front.  I noticed my truck vibrating on the way home so i checked the tires and they were fine.  I felt the rims and that one was pretty much on fire. I jacked it up and the tire spins but you can hear it dragging. what is the likely cause?
Offline Toolmaster
Re: brakes dragging
« Reply #1 on: March 06, 2008, 03:26:32 pm »
Did you check the wheel bearing's ?
When was the last time you looked at the brakes ? could they be worn out ?
I would pull it apart and check every thing, brakes, bearings, seals, ball joints, tie rods, shocks,
break lines any other thing you can get to while in that area.
Offline ccz145a
Re: brakes dragging
« Reply #2 on: March 06, 2008, 03:28:55 pm »
Left front brake hose. They commonly have this problem, the rubber deteriorates, leaving a flap inside. Acts like a check-valve and brakes don't release. Crack the bleader, and let the pressure off, only works until you apply the brakes again, though.
Re: brakes dragging
« Reply #3 on: March 06, 2008, 03:36:38 pm »
Ditto on both the above.  Crack the bleeder (it will be on fire too after it sticks, so ...) if it rolls afterwards its the hose, otherwise check the rest....
Re: brakes dragging
« Reply #4 on: March 06, 2008, 05:19:38 pm »
i'm trying to change the hose but i cant get the bolt out of the frame, any hints?
Re: brake hose
« Reply #5 on: March 06, 2008, 05:26:55 pm »
There is a 15/16" capture nut on the inside of the frame and a clip on the outside.  Are you trying to remove the line completely?  Did you get the hardline removed from the connector?
Re: brakes dragging
« Reply #6 on: March 06, 2008, 05:28:44 pm »
How about keeping all of this together instead of posting multiple places...  I am merging the other post...
Re: brakes dragging
« Reply #7 on: March 06, 2008, 07:01:56 pm »
Aight i got it...i was working in the dark so it was a pain but my brother gave me a hand. That was the problem, thanks for all of the help. Sorry about separating the posts.
Don't spell swear words with special characters, this is not allowed here, it adds nothing to the post except something I have to remove. - Captkaos
« Last Edit: March 07, 2008, 12:05:04 am by Captkaos »
Offline CuatrodeMayo
  • Back in the saddle again
Re: brakes dragging
« Reply #8 on: April 30, 2008, 12:28:16 pm »
Sorry to bump this thread, but I am having the same problem with my 87 Silverado.  I can't get the things out of the frame.  It appears that on the outside of the frame there is a 5/8 nut integrated with the hose end.  I can't get anything to budge and (stupidly) I have partially rounded off the nut on the outside.  Any ideas?
« Last Edit: April 30, 2008, 12:32:25 pm by CuatrodeMayo »
Offline ccz145a
Re: brakes dragging
« Reply #9 on: April 30, 2008, 01:06:46 pm »
If it's rounded bad enough, it might be vise-grip time. if not, then use a line wrench that wraps around the landings a little more. As long as you don't destroy the part that stays in the frame all is well.
Get some leverage, I've had to get creative in the past. You can use a pipe, or, my favorite, a very large box end wrench to fit over the wrench on the part and give you a longer fulcrum.
Good luck, my friend.
Re: brakes dragging
« Reply #10 on: May 01, 2008, 08:44:19 am »
If its that bad you might want to consider just getting a new flex hose etc. Then just cut the old stuff out.
Offline SUX2BU99
Re: brakes dragging
« Reply #11 on: May 07, 2008, 05:16:07 pm »
Put my truck up on stands last night, tried spinning the passenger front rim and it wouldn't free-wheel at all. Could hear what sounded like the brake pad dragging on the caliper. It takes some effort to actually spin the wheel. Drivers side is a little better but not much. Brake hoses probably, eh?
Offline frogman68
Re: brakes dragging
« Reply #12 on: May 08, 2008, 06:45:34 am »
Sounds like a frozen piston in the caliper to me
Offline SUX2BU99
Re: brakes dragging
« Reply #13 on: May 08, 2008, 02:08:55 pm »
I think I'll pull the wheel off and see what I can see. Crack the bleeder as suggested and see if that helps at all.
Offline SUX2BU99
Re: brakes dragging
« Reply #14 on: May 09, 2008, 11:08:24 am »
Poking around there last night I see where the hard line connects to the flex hose right at the frame. It doesn't appear that the hard line has to come off at the frame connection if wanting to remove the flex hose, right? And it appears that there are only two nuts on the flex hose to undo: at the caliper and at the frame hard line connection. Correct?
