Author Topic: Can I keep the TBI with a new, bigger engine?  (Read 14439 times)
Re: Can I keep the TBI with a new, bigger engine?
« Reply #15 on: March 15, 2008, 07:02:17 am »
what is the TPI,and ASI and how do i set them that may be my problem with my truck i have a dead spot double peddle to get past it.
76 scottsdale, are you swapping the entire axle assembly or just ring and pinion?
Offline 1976Scottsdale
« Reply #16 on: March 15, 2008, 03:40:19 pm »
My bad, I am just swapping the ring and pinion... I hope for now.  If I need a new carrier, then I guess I'll be doing that too.  Getting ready to find out what gears I have shortly.  Just have to go get a new gasket for the cover.  Then I won't be having to beg for answers to my educated guesses, I will have some real facts.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #17 on: March 25, 2008, 11:38:45 pm »
I did that same swap in my old 87 r-10.  I put a 1973 400 in it and kept the tbi.  it came with a 305 originally, th700r4 and 2.something gears.  I got a 350 computer box out of a suburban for the chip, and put new 454 injectors in the tbi and used the original parts from the tbi setup otherwise.  also i had a mild rv cam in the engine, tbi's don't like hot cams without major changes, starting with a custom chip.
here's a pic of it right before it went in...
