Author Topic: Massive oil use, looking for suggestions  (Read 14511 times)
Re: Massive oil use, looking for suggestions
« Reply #15 on: March 11, 2008, 09:48:16 pm »
Then I would just replace the valve seals and see what happens.
I'll give it a try.
« Reply #16 on: March 12, 2008, 12:18:12 pm »
safest way to do it with the heads on is in the firing order with a breaker bar on the crank so it won't move. Pressurize the cylinder with air and change #1 and #6 seals intake and exhaust. Rotate the crank clockwise 1/4 turn do #8 & #5, 1/4 turn #4 & #7, 1/4 turn do #3 & 2. This way if you lose air pressure for whatever reason your valve won' fall completely out of the guide into the engine.
Offline 79wideside
« Reply #17 on: July 16, 2008, 10:07:08 am »
Did you get a chance to try the stem seals yet? Just curious, as mine is doing the exact same thing!
« Reply #18 on: July 16, 2008, 10:55:32 am »
No, the engine needs rebuilt.  The PO neglected the oil change intervals it seems.  The main/rods rattle on start up for a few seconds till the oil pressure builds up.  I am working on getting a replacement car for my son that gets better gas mileage.  Goes through a quart every 4-500 miles but runs exceptionally well.  Just took it this weekend on a 240 mile round trip, didn't miss a beat and got close to 20 mpg, that is with me driving and all rural 65 mph or slower, but consumed 1/2 quart.
Offline 79wideside
« Reply #19 on: July 16, 2008, 04:46:14 pm »
Mine has that same rattle too! I am thinking the same way you are, get another engine!
