Author Topic: Sandblaster  (Read 14512 times)
Offline Mamby
Sandblaster
« on: March 25, 2008, 10:50:01 pm »
Anyone know of a cheap, but decent sandblaster? i have a k10 thats a bit rusty and the paint is faded. Not sure how much it would cost for someone to sand it down and paint it, but i figured it would be cheaper to sandblast the things that dont need replaced. Also, anyone know if i could get just a piece of a new bed? Ill post pics tomorrow probably of what im in need of. thanks
Offline HAULIN IT
Re: Sandblaster
« Reply #1 on: March 26, 2008, 12:04:05 am »
Mamby, You do not want to sandblast your bodypanels, other than rusted spots, around the edges or other "hard" areas. The heat from the abrasiveness will warp normal flat sheet metal areas. You want to either sand off or chemically remove the paint if thats what you want to do. Check the on-line catalog on this site for the bed piece, not sure what piece your referring to, but Chris will most likely have it. Lorne
Offline Mamby
Re: Sandblaster
« Reply #2 on: March 26, 2008, 11:13:48 pm »
Ok, so looking at another thread, i think since im on springbreak started friday, and i get paid Wednesday, im going to go buy a DA sander, and probably a spray gun.
If i was to get the panels down to bare metal, what steps would i need to take to paint the panel and have a nice finish to it that wont start falling off after a week?
Offline gbskunk2006
Re: Sandblaster
« Reply #3 on: March 28, 2008, 10:10:12 am »
Make sure you have a big enough air compressor.  I tried running my DA on an 8 gallon compressor and it was constantly running until it eventually burnt out the motor in no time.  Luckily, I got a sweet deal on a new 60 gallon compressor, thereafter it worked like a charm.
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Offline Mamby
Re: Sandblaster
« Reply #4 on: March 28, 2008, 08:38:18 pm »
Ok, i wasnt planning on running a high PSI because i saw somewhere it might warp the metal if you run alot of pressure and apply alot of force, but i might look a compressor when i go and buy the DA sander.
Re: Sandblaster
« Reply #5 on: March 28, 2008, 10:23:04 pm »
You want a 60 gallon 5.5 HP two stage compressor minimum. One thing to keep in mind. The best primer / foundation in the world for a new paint job is factory paint. Providing it is in OK shape as far as checking, peeling, rust, etc. In other words you don't have to take it down to bare metal unless the paint is really in that bad of shape. As far a s primers I like a self etching rust inhibitive primer. Martin Senior makes a good one. Called etch filler, it is allot like Duponts Vari Prime but less than half the cost. A good high build 2K urethane primer is in order to give a nice sealed base. 5 Star makes a good 2K primer. 3 parts, primer, reducer, & activator. Epoxy primers / sealers are good if you want a final barrier under the paint. They are also good for bare metal, but don,t have the etching quality. You can how ever etch bare metal with Duponts 244S.
Offline Mamby
Re: Sandblaster
« Reply #6 on: March 28, 2008, 11:02:15 pm »
if i was to take it down to the bare metal, what steps would i need to do? Sorry for all the nooby questions, never done this before and i just want to get it decent the first try
Offline dunedigger
Re: Sandblaster
« Reply #7 on: March 28, 2008, 11:10:11 pm »
I am spoiled here in Michigan.  There is a local soda blaster that is cheap and sandblasting is near free too.  Here is a link to my box that was done with a paint striper and then a da with 80 grit paper.  After this was an etching primer and then blocking primer sealer and paint.  I always told people that factory paint was the best primer too.  The painter that painted my blue truck told me that the solvets will losten up the old paint and cause the new paint to shrink.  I didn't beleive him so he painted a panel half old paint and what do you know, it shrunk ???
forgot the link  here it is    http://forum.73-87chevytrucks.com/smforum/index.php?topic=7549.0
Re: Sandblaster
« Reply #8 on: March 29, 2008, 02:41:56 am »
It couldn't have been factory paint. I have panted over more factory paint than I care to remember, have never had the new stuff shrink or pull scratches. I have seen it do it if the old paint was checked or crazed.
 As far as taking all the paint off. Chemical stripping is one way. Aircraft stripper works the best I usually use this method on a hood or large panel that is easy to warp with the next method.
I like to use a large variable speed grinder, with an 8" soft pad for self stick paper. I use 8" 36 grit paper to take it all off. let the paper do the work, not much pressure, & 1,800 to 2,000 RPMs. Then sand the metal with the DA and 6' 100 / 180 grit paper. Next is etch the steel and epoxy primer, or self etching primer. Then high build urethane 2 K primer. Block sand that and reprime if needed. Then finish sand with 400 grit on the DA, or wet sand with 400 then 600 and a soft block.
Offline gbskunk2006
Re: Sandblaster
« Reply #9 on: March 29, 2008, 10:30:25 am »
When I was planning on having my truck painted, the biggest issue seemed to be that the older vehicles were painted using a lacquer finish and does not react well with today's modern paints.
My resto project is going to be a "daily driver" so taking everything right down to the metal was never really considered.  I used a combination of 200 -> 400 grit paper with my DA sander to ensure there was no "shine" left on the surface.  Once in the shop, my painter sprayed the whole thing down with a good primer coat before applying the base coat and finally the clear coats.
Re: Sandblaster
« Reply #10 on: March 29, 2008, 12:02:55 pm »
I agree older unkept lacquer paint is not a good base.
Offline Mamby
Re: Sandblaster
« Reply #11 on: March 31, 2008, 11:53:13 pm »
How do you guys get you paint? do you go to a shop or order it off the internet? if you guys could give me a link to a site i would be grateful :)
Re: Sandblaster
« Reply #12 on: March 31, 2008, 11:55:29 pm »
I buy mine from a local parts store that has a paint counter.
Offline Redneckchevy
    • Photo Bucket
Re: Sandblaster
« Reply #13 on: April 01, 2008, 12:07:39 am »
Ditto i got a auto body paint shop down the road...Im sure if u snoop around u can get a good source
Offline hotrod24
Re: Sandblaster
« Reply #14 on: April 01, 2008, 12:26:51 am »
« Last Edit: April 01, 2008, 12:33:14 am by hotrod24 »
1978 pontiac grand prix...
