Author Topic: robbing parts from vans...  (Read 8629 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: March 29, 2008, 09:55:05 am »
Looked at a 87 gmc full size van, it appears the grille would work on a truck, is this correct? What else interchanges with the trucks? Maybe steering column, windshield, rear ends, front suspensions?
Re: robbing parts from vans...
« Reply #1 on: March 29, 2008, 10:05:17 am »
Rear ends are different spring perch width, and overall width. I have never seen nor had it confirmed, but I have heard the windshields are the same. I know a guy that said he used van front suspension parts control arms in his C10.
« Reply #2 on: March 29, 2008, 11:55:49 am »
hmmmmm Narrower or wider???
« Reply #3 on: March 29, 2008, 12:06:15 pm »
I don't remember but I think it is wider.
« Reply #4 on: March 29, 2008, 01:23:41 pm »
OK never mind :(
Offline Destro
« Reply #5 on: April 01, 2008, 01:16:19 am »
grilles interchange just fine
« Reply #6 on: April 01, 2008, 03:27:35 pm »
The grille will swap up to a certain year, but Vans are Unibody, so the axle perches are different.
Offline Bowtie Bomber
  • Rolling American Iron
« Reply #7 on: April 01, 2008, 07:57:13 pm »
The grill will work. I should know, that's what mine's off of.  ::)
My truck is my flying fortress, the road is my sky, and Toyota's are the enemy bunkers that need a busting.
Offline monte85
« Reply #8 on: April 02, 2008, 08:40:51 pm »
grilles look the same but won't swap over. when i ordered the new one for my truck a couple years back, gm sent me a van one instead. mounting tabs are different.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
Offline Stewart G Griffin
« Reply #9 on: April 06, 2008, 09:02:18 pm »
1) the gauge panel interchanges with a chevette/T-1000.
2) So, this, apparently, means that the parts that interchange with the 73-87-91's actually range from 71 to about 96ish because i don't think the new-style gm vans came out until 97 or so?
« Reply #10 on: April 06, 2008, 11:29:45 pm »
I don't think your gonna get a 71 - 75ish grille in a C K truck!
« Reply #11 on: April 07, 2008, 11:18:25 pm »
i can try;  Wire-ties will do wonders.
« Reply #12 on: April 07, 2008, 11:26:14 pm »
Van grilles were the same/simular from about 81-87...  As far as I know nothing from the 70's will work
