Projects Posts (NOT VEHICLES)
Radiator core repair
Topic: Radiator core repair (Read 36801 times)
77 step
April 06, 2008, 10:36:19 pm »
Here is what I have been playing with this weekend. My core support was rusty and had some weak spots.
Sean
1977 K-10 stepside under slow reconstruction.
77 step
Re: Radiator core repair
April 06, 2008, 10:45:37 pm »
I made a patch piece for the lower passenger side where the inner fender mounts. I welded hex nuts (which I had soaked in muratic acid to remove the zinc coating) to the backside. Then I welded the patch in and ground it smooth. By the way, I rinsed the nuts with baking soda and water to neutralize any acid left on them.
Sean
77 step
April 06, 2008, 10:52:20 pm »
There was also a rust hole near the passenger side mount. I drilled out the spot welds, and cut out the pieces that were rusty.
Sean
77 step
April 06, 2008, 11:03:04 pm »
Then, I cleaned up the inside, and made a patch piece. I straightened all the bends out in the original piece, and traced it on a new piece of steel. Then cut the patch out with the plasma cutter, and folded it into the original shape.
Sean
77 step
April 06, 2008, 11:08:52 pm »
Next, I welded in the patch, and ground the welds. I have to get a piece of 16 gauge to make the inner "box". That meant done for now, time for some beer
Sean
77 step
April 06, 2008, 11:39:48 pm »
Sorry, the title of the thread should have read "Radiator core support repair". I tried to change it, but I was unable.
Sean
hotrod24
April 06, 2008, 11:45:55 pm »
did you go to modify and try changing the subject
Last Edit: April 06, 2008, 11:57:28 pm by hotrod24
1978 pontiac grand prix...
77 step
April 07, 2008, 12:03:10 am »
Yes, Hotrod, I did. I get a white screen with:
Database Error: Lost connection to MySQL server during query
File: /vservers/chevy/htdocs/smforum/Sources/Subs-Post.php
Line: 1895Database Error: MySQL server has gone away
File: /vservers/chevy/htdocs/smforum/Sources/Load.php
Line: 2030
Warning: Unknown(): A session is active. You cannot change the session module's ini settings at this time. in Unknown on line 0
Maybe a moderator will see it and change it for me?
Sean
JJSZABO
April 07, 2008, 07:54:27 am »
Good job - I had to do the same to mine
Jeff
86 Chevy C-10
350, TH400
April 07, 2008, 12:28:13 pm »
There is a bug in the forum software that won't allow you to change the first post. Sweet work BTW.
77 step
April 07, 2008, 08:44:17 pm »
Well, here's what I did tonight. I reattached the passenger side mount, got my piece of 16 gauge, cut it out, and folded it into shape. Next was punching holes in the new piece for plug welds. Then, I clamped it in place andwelded it in.
Sean
JJSZABO
April 07, 2008, 08:47:00 pm »
That is some nice work 77 - where did you learn to do metal work?
Jeff
86 Chevy C-10
350, TH400
77 step
April 07, 2008, 08:49:27 pm »
Lastly, I finished welding the mount, and test fit it. Pretty much done now except for a little bolt hole stretching and some paint. Time for a cold one.
Sean
77 step
April 07, 2008, 08:55:54 pm »
Thanks Jeff.
I learned most of it here in my garage (welding,cutting,etc) .
I work as a mechanic for a roofing company, so I do have the benefit of having friends who make flashings, downspouts, chimney caps, etc. I have learned some of the "folding" or breaking from watching them.
Sean
JJSZABO
April 07, 2008, 09:00:29 pm »
Thats great - good ole DIY knowledge - awesome job
Jeff
86 Chevy C-10
350, TH400
