Author Topic: short bed  (Read 72662 times)
Offline hotrod24
Re: short bed
« Reply #15 on: April 08, 2008, 09:30:31 pm »
cool
1978 pontiac grand prix...
Offline hotrod24
Re: short bed
« Reply #16 on: April 22, 2008, 09:35:56 pm »
is there a way that i can slide my bed back so i can get to the back of my cab becuase there is some bad spots there
« Last Edit: April 22, 2008, 09:54:01 pm by hotrod24 »
Offline frogman68
Re: short bed
« Reply #17 on: April 23, 2008, 02:17:09 am »
Why not just take it off ?
If the tank is still in I wouldnt want to be grinding or welding back there with the tank in
Offline hotrod24
Re: short bed
« Reply #18 on: April 23, 2008, 12:31:59 pm »
yea good idea could i take it off and grinde out the spot welds and take it apart
Offline frogman68
Re: short bed
« Reply #19 on: April 23, 2008, 12:42:01 pm »
Just unbolt the bed and put a 4X4 inside the rail near the center and pick it up with a cherry picker
Offline hotrod24
Re: short bed
« Reply #20 on: April 23, 2008, 01:00:54 pm »
i dont have cherry picker where is all the spot welds in the bed
Offline JJSZABO
Re: short bed
« Reply #21 on: April 23, 2008, 01:52:51 pm »
the only welds in the bed are where the rear vertical post (stake pockets) meet the bed.  There are two spot welds there - other than that they unbolt with about 50 thousand bolts (just kidding about the bolts - there are about 100 ;D)
Jeff
86 Chevy C-10
350, TH400
Offline hotrod24
Re: short bed
« Reply #22 on: April 23, 2008, 03:50:30 pm »
thanks jeff i started taking bolts out what would be the best way to get the spot weld out
Re: short bed
« Reply #23 on: April 23, 2008, 03:58:03 pm »
The only welds should be near the tailgate posts. Die grinder
Offline hotrod24
Re: short bed
« Reply #24 on: April 23, 2008, 07:25:52 pm »
thanks guys i have started the ter down here is some pics
Re: short bed
« Reply #25 on: April 23, 2008, 08:57:08 pm »
Movin right along hotrod Keep it up!
Offline hotrod24
Re: short bed
« Reply #26 on: April 23, 2008, 09:05:10 pm »
thanks vile it is more work but i can do it i need to take my tool box off and the other inner wheel tub and could you tell me what i could put on the bed floor bolts so it will be easier to get them off all i have is wd40 and silicone
« Last Edit: April 23, 2008, 10:36:14 pm by hotrod24 »
Offline hotrod24
Re: short bed
« Reply #27 on: April 24, 2008, 07:43:12 pm »
today i got my tool box off and the other inner wheel tub i just have the spot welds now could i use a grinder with a cutting wheel or would a die grinder do the best
Offline JJSZABO
Re: short bed
« Reply #28 on: April 24, 2008, 08:41:48 pm »
A grinder with a cutoff wheel would work if you can get it in there.  It was tough for me to get my die grinder to fit in there.
Jeff
86 Chevy C-10
350, TH400
Offline hotrod24
Re: short bed
« Reply #29 on: April 24, 2008, 09:07:26 pm »
yea my cut off wheels are thick so it will be a tight fit maybe i could grind them
