Author Topic: kick panel cover  (Read 11174 times)
Offline hotrod24
kick panel cover
« on: April 09, 2008, 11:39:49 am »
hey when i redone my interior i had a some trouble getting the placstic cover out is there a easy way to do this
« Last Edit: April 09, 2008, 12:33:24 pm by hotrod24 »
1978 pontiac grand prix...
Online Captkaos
Re: kick panel cover
« Reply #1 on: April 09, 2008, 11:42:45 am »
Are you talking about where the Vents are?
Offline hotrod24
« Reply #2 on: April 09, 2008, 12:39:51 pm »
yes
Offline Swims350
    • Cars and trucks
« Reply #3 on: April 09, 2008, 08:26:32 pm »
it's got a few bolt head screws with large washers on it or supposed to anyways.
Probably 5 or so all staggered about and they are 7mm I think.
www.cardomain.com/id/benwa454
Offline JJSZABO
« Reply #4 on: April 10, 2008, 09:17:17 am »
If I remember correctly, there are eight bolts that hold it in.  The vent panel gasket might be stuck to the cab.  Wiggle, jiggle and flex it out - that's what I had to do.  It will come out ;D
Jeff
86 Chevy C-10
350, TH400
Offline ccz145a
« Reply #5 on: April 10, 2008, 09:26:06 am »
Be sure to check the very bottom, the scrws near the floor on my truck were caked with 33yrs of grime and hidden.
Where is the hold up. Describe what is or is not loose.
Offline JJSZABO
« Reply #6 on: April 10, 2008, 09:41:06 am »
Or better yet, post some pics
Jeff
86 Chevy C-10
350, TH400
Offline SUX2BU99
« Reply #7 on: April 10, 2008, 11:34:28 am »
I remember the driver side one I believe being quite the pain to get out. It has to be finnessed out of it's hole I found because there is a flange on the panel that is on the other side of the hole. That flange I think it just slightly larger than the hole it has to come out of. So you have to wiggle it around until you find the sweet spot to get it out. The e-brake pedal can add more aggravation to it too.
Offline hotrod24
« Reply #8 on: April 10, 2008, 06:14:36 pm »
well last summer i took them off and it was a pain and there was no build up behind them so that was good but i guess that is the best way just wiggle and pull
Offline dueprocess
  • My 8yr old's tonka toy!
« Reply #9 on: April 10, 2008, 07:26:25 pm »
odd, mine is the opposite wa around! The drivers side came off like a champ text book style, but my passenger side has not come off and it's been a couple days of jacking with it here and there!!!!!!
1978 Chevy K10 / 454bbc / Dana 44 with chromoly axles / 6in susp & 3in BL / 38.50x15 Boggers(rims 15x14)!
Online Captkaos
« Reply #10 on: April 11, 2008, 11:45:55 am »
Generally they have to be pushed up in the hole and then the bottom pulled out.
Offline hotrod24
« Reply #11 on: April 11, 2008, 12:42:01 pm »
that makes sense does it really work
