Author Topic: heat/AC wiring diagram  (Read 65019 times)
Offline 79diesel
Re: heat/AC wiring diagram
« Reply #15 on: April 16, 2008, 09:08:37 pm »
thats what i was thinking but which wire is the power source to to the fuse panel for the heater?
« Reply #16 on: April 16, 2008, 09:12:01 pm »
In the schematic it's the brown wire. your truck may be different color but do you see where it says fused ign feed 3? The fuse panel has a bussed connection that is energized by the ign switch. If your factory harness is hacked then just run a fused power feed switched from the fuse block,.
Offline 79diesel
« Reply #17 on: April 16, 2008, 09:14:51 pm »
ok awesome thanks
