Author Topic: converting long bed to short bed  (Read 7109 times)
Offline smoke
« on: April 15, 2008, 08:58:02 pm »
buying a 88 1-ton 4wd.single rear wheel.wanting to put a short box on it.any pointers or tips in doing this?even if it is negative.let me hear it.thanks
Offline Fordeatinz71
  • 78k miles and counting
Re: converting long bed to short bed
« Reply #1 on: April 15, 2008, 09:01:45 pm »
if you search a bit, Vile Zambonie just did this to his '74 GMC C1500.  he posted good pics and even a video of the truck afterwards...
as far as positives/negatives?  well, positives is that it looks cool to see a 1-ton 4x4 shortbed (i'm gonna have one soon), as a negative, you lose bedspace, the ride will be a little worse due to the shorter wheelbase...you can't really haul a gooseneck trailer anymore (if you did to begin with)...otherwise...it's not really that bad...if you want it, GO FOR IT!
BTW, welcome aboard!
« Reply #2 on: April 15, 2008, 11:22:58 pm »
Mount the SWB bed, mark the frame front/rear and start hacking....  See the thread in the Projects section with this title.
Offline chevy754x4
« Reply #3 on: April 16, 2008, 09:54:25 pm »
1 ton 4x4 would be cool. as far as shortening the frame, it isn't as bad as it sounds.....just remember to measure, measure, measure
Offline DnStClr
« Reply #4 on: April 16, 2008, 11:14:17 pm »
Good luck with your project smoke.I think the fuel tanks might be different aren't they?
Don
87 Chevy Silverado
Offline smoke
« Reply #5 on: April 20, 2008, 12:19:30 am »
ya thanks guy's.i will measure twice cut once.found the post about cutting it down.so i do need to mount the bed first?there isn't a magic number to cut out?also the gas tank is already in the back in the frame.so shouldn't have to really mess with that.
