Fuel Issues?
Topic: Fuel Issues? (Read 6015 times)
VeeTwin60
Fuel Issues?
April 27, 2008, 02:38:40 pm »
Hey Guys - The other day, my truck started stuttering as if it were out of gas. It is very intermittent, as it will go back to normal just a little bit later. When it is stuttering, if you push the accelerator it will cough and act like it would if it had too big of a carburetor. When it is normal, it works just fine.
Could this be a blockage in the fuel filter? Could it be a fuel pump going out? Any other ideas?
350 cu.in. w/Holley 600 CFM 4bbl Street 1850C
Thanks!
1986 C-10 1/2 TON 2WD SWB
77 step
Re: Fuel Issues?
April 27, 2008, 02:46:07 pm »
Holley,
Power valve is my guess.
Sean
1977 K-10 stepside under slow reconstruction.
DnStClr
Re: Fuel Issues?
April 27, 2008, 03:02:40 pm »
Sure could be a power valve. Always start checking with the easy stuff. Air filter. vacuum lines. fuel filter. plugs. Look inside of the distrib. cap and see if it's cracked.
Don
87 Chevy Silverado
Blue 82
Re: Fuel Issues?
April 27, 2008, 05:06:20 pm »
are you using E10?
VeeTwin60
Re: Fuel Issues?
April 27, 2008, 07:41:18 pm »
Not knowingly. Would it be labeled on the pump?
I think I'm going to rebuild the carb and replace the plugs and wires - It won't hurt, I know they both need it.
TexasRed
Re: Fuel Issues?
April 27, 2008, 08:25:29 pm »
Replace the plugs and plug wires first and see if that helps.
E10 is usually found on the pump, it would say, "Contains Ethanol" or "Contains upto 10% Ethanol".
VeeTwin60
Re: Fuel Issues?
April 28, 2008, 01:58:20 pm »
Okay - I've replaced the plugs and wires (which it needed). I've rebuilt the Holley. After reinstalling the carburetor, I turned the truck over. Now, I know the bowls are empty, so it will take a few tries to fill them up and fire it off. However, it never fired. So, I disconnected the fuel line and diverted it into a container. I then turned the truck over - nothing came out of the hose
So, I go back to the fuel pump question - is it possible for a fuel pump to operate intermittently?
77 step
Re: Fuel Issues?
April 28, 2008, 04:50:04 pm »
Is your pump mechanical, or has it been changed to electrical? My guess is that the mechanical one works or doesn't. An electrical one could be intermittent.
How about a suction leak? Could the fuel pump be sucking air through a cracked/rusted/loose line?
Could the pickup tube in the tank be broken?
How about a blockage in the lines?
If you have access to a HAND OPERATED vacuum pump, or brake bleeding pump, you could try to draw a vacuum on the line to check for a leak or blockage. If the gauge won't come up off 0, it is probably a leak. If it goes up and up as you pump, and holds but you get no gas - blockage. If it goes up, but slowly falls as gas is drawn to it, fuel pump is not working.
I stressed hand operated because of the dangers of mixing electricity and gasoline.
Hope this helps... good luck!
I
Sean
VeeTwin60
Re: Fuel Issues?
April 28, 2008, 06:05:45 pm »
It is mechanical - and I had the same thought as you... a mechanical one works, or it doesn't - no in between.
But... it was the fuel pump.
I changed it and it runs like new again.
77 step
Re: Fuel Issues?
April 29, 2008, 07:31:23 am »
Good job!
Sean
Fuel Issues?
