Author Topic: Cabs  (Read 4752 times)
Offline 75 C20
Cabs
« on: May 04, 2008, 09:57:32 am »
i don't know if it has been brought up before but i thought id ask. has anyone ever take a big truck cab/ c-60 style wit the small back windows and put it on a regular 10-30 series truck? does every thing work- i thought i hear something about the steering column isn't at the right angel?
has anyone ever attempted/seen this done?
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: Cabs
« Reply #1 on: May 04, 2008, 08:11:03 pm »
The floors are flat and don't clear the trans etc.
Offline HAULIN IT
Re: Cabs
« Reply #2 on: May 05, 2008, 09:55:25 am »
Yes the cab will not "go on & all line up". If you are wanting the small back window for a different look, using just the back panel would be the way to go. I checked this out years ago, after seeing nice clean rockers & cab corners on a few of those trucks (due mostly to being up so high out of the slop I suppose). The floor & some of the firewall are different & since the floors are one of the first things to rot, it makes it not a very likely swap since you need the floor from the donor cab. Lorne
Offline Stewart G Griffin
Re: Cabs
« Reply #3 on: May 06, 2008, 10:03:57 am »
That's sharp;  i forgot that the topkicks had that smaller window.
Would this small window be legal on a 1/2 pickup?
