Author Topic: Accelerator cable  (Read 6855 times)
Offline HAULIN IT
Accelerator cable
« on: May 18, 2008, 04:23:02 pm »
Chris, Do you carry throttle cables? The one in my truck started binding up ('85 V8 cable). I went to the local store to get one, what they have is about 4" longer than the old one. I looked on Advance Auto's website they show it as 21 1/4" long (which is what my old one is) Took the part number to the store, opened the box & it too is 25" long. This will work, but it is all twisted up looking like it's a few inches too long, oh yea it is! Just wondering if anyone has a solution? Thanks, Lorne
Offline Stewart G Griffin
Re: Accelerator cable
« Reply #1 on: May 18, 2008, 07:25:21 pm »
i would try the/a dealer for these things---throttle cable, return springs etc.  They are engineered right, and "mundane" stuff like that is usually pretty cheap--even considering it's from a dealer.
Also, the salvage yard.
« Last Edit: May 18, 2008, 07:31:23 pm by Stewart G Griffin »
« Reply #2 on: May 19, 2008, 09:29:44 am »
I don't have cables.  I would check the dealership.  The do have some slack in them though ( doesn't go straight out to the carb )
Offline HAULIN IT
« Reply #3 on: May 19, 2008, 11:49:35 am »
Ok Thanks, Yea I realize there is a little slack. The old one just looks more correct, what seemed strange was the listing for the length was the same as my old one, but in both boxes were about 4" longer. They probably found that they could cover more years/engines/models ect. with the one a little longer. I may check out the dealer. Thanks, Lorne
« Reply #4 on: May 19, 2008, 01:46:46 pm »
most likely so.  The length isn't that important as much as the connectors.
« Reply #5 on: May 20, 2008, 05:36:45 am »
You sure you didn't get a six banger cable in the box? They were quite a bit longer than the V8 cable.
Offline JJSZABO
« Reply #6 on: May 20, 2008, 08:03:45 pm »
I had the same problem Lorne.  I tried every aftermarket place around here - Pep Boys, NAPA, Advanced, Auto Zone, Car Quest..... all too long.  I finally went with a Spectre / Universal Braided Stainless Throttle Cable Kit, I bought at Auto Zone - worked like a champ, and looks good to ;)
Jeff
86 Chevy C-10
350, TH400
