Author Topic: Box removal, best way to remove the bolts  (Read 9065 times)
Offline Steve Crum
« on: May 18, 2008, 10:05:30 pm »
I'm going to pull the rusty box off my 87' GMC and replace it with the redone box off my 84' Chevy. I don't want to have to torch the 8 bolts on this like I had to on the 84' box. I've been soaking the nuts and lower end of the bolts every day or so with PB Blaster for the past week. I had hoped to have Bad Brad stand on the bolt heads while I hammered them from below with an IR Thundergun but it rained and BB sneaked back off to college. Anybody have any neat tricks to this, or are these just a ball buster any way you do it?
Offline hotrod24
Re: Box removal, best way to remove the bolts
« Reply #1 on: May 18, 2008, 10:51:04 pm »
Well i had to grind the heads off of two because thay just turned in the bed floor and the rest come out with a bracker bar and wrench it was not hard to get them out. have you tryed to turn them yet?
p.s a sawzaw is handy to
« Last Edit: May 18, 2008, 10:54:35 pm by hotrod24 »
1978 pontiac grand prix...
« Reply #2 on: May 19, 2008, 05:44:55 am »
I almost never waste my time, I fire up the blue wrench right off the bat!
Offline 87GMC2WD
« Reply #3 on: May 19, 2008, 08:21:18 am »
my bolts turned too, so  i welded took the flat bar from a chain link fence and welded it between two of them and then they came right off with a breaker bar.
Offline HAULIN IT
« Reply #4 on: May 19, 2008, 11:55:38 am »
Steve, Something I've done is this: Get a big (3/4" or so) washer standing up or a short piece of pipe. Weld it to the top of the bolt. Insert a prybar through the hole, bucked up against the bedside to keep them from spinning. Cut if off, go to the next one. A little heat on the nut will help greatly also. Have fun with that! Lorne
Offline Steve Crum
« Reply #5 on: May 21, 2008, 10:11:34 am »
Thanks for the suggestions, I guess I wasn't too clear on removing these. I would like to save these, but since I don't have anyone around to help I think I'll just cut them and replace them with chinese bolts from TSC.
« Reply #6 on: May 21, 2008, 10:26:27 am »
If you have a welder, I have tack welded them to the floor to get them out.
Offline N2TRUX
« Reply #7 on: May 22, 2008, 07:53:30 am »
Maybe some of this...:0
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #8 on: May 22, 2008, 08:14:14 pm »
^ That'll get the truck right off that bolt! ;D
Offline DnStClr
« Reply #9 on: May 23, 2008, 02:36:53 pm »
If you can reach the nuts with a die grinder, you can make  pie shaped cuts til a wedge is removed, then chisel the rest of the nut off. Careful grinding can save the bolt.
If you have a welder you might also weld a 3/4" nut to the top of the bolt head and remove the bolt with an impact gun while holding the bottom nut from turning.
Don
87 Chevy Silverado
Offline werewolfx13
« Reply #10 on: May 27, 2008, 10:56:59 am »
I've done it by grinding a notch in the bolt head, as close to the bed floor as possible, tack welded the nut underneith, and used a chisel and hand sledge to spin the bolt..This only works after the bolt has spun in the hole and rounded the hole out.
Chris
'83 Chevy c10 Silverado SWB
