Author Topic: MPG Pt.1  (Read 186586 times)
Offline Stewart G Griffin
Re: MPG Pt.1
« Reply #165 on: August 17, 2013, 04:51:49 pm »
sorry i feel i kinda hijacked your thread ill try to stay out of it more, i was just a little curious as to what you were doing different than me on your truck.
That's ok;  i will get into more detail a.s.a.p.
Offline hondarider188
Re: MPG Pt.1
« Reply #166 on: August 19, 2013, 04:17:43 pm »
ok thanks
1983 K10 silverado
Re: MPG Pt.1
« Reply #167 on: August 30, 2013, 08:58:05 pm »
i think the main things i'm doing "differently" are 2WD---4WD is a little heavier.  Smaller tires and 2.56 rear diff.
273 miles, 17.254 gallons = 15.88 mpg
BP   $3.529 per gallon.  $60.89 to fillup
Re: MPG Pt.1
« Reply #168 on: August 31, 2013, 10:17:16 am »
This mileage is atrocious and WILL be dealt with.
Re: MPG Pt.1
« Reply #169 on: August 31, 2013, 11:08:35 am »
yeah i see what you mean. i know 4wd isnt helping me at all but i should still be getting a little better than i am. i am going to be going down a little in tires. and i am jetting my carb better once i get the time to do so. then well see how well it can do.
1983 K10 silverado
Re: MPG Pt.1
« Reply #170 on: October 06, 2013, 09:43:18 pm »
284.1 miles/ 17.297 gallons = 16.42 mpg
$3.19 per gallon regular at Exxon.  $55.33 to fillup
Re: MPG Pt.1
« Reply #171 on: October 09, 2013, 04:14:04 pm »
i recently took my jets down to a #70 from a #72 and then the rods down to 51 from 52. and i also put in a softer power piston spring. its seems to be getting better mpg, i haven't checked it yet and probably wont for a while since its in the shop now getting ready for paint. I think that a next big thing for me to do is to upgrade the ignition system since im still running stock.
1983 K10 silverado
Re: MPG Pt.1
« Reply #172 on: August 09, 2014, 06:53:34 pm »
274.3 miles/16.316 gallons = 16.81 mpg
$3.399 per gal regular Exxon.  $55.46 to fillup
Re: MPG Pt.1
« Reply #173 on: August 09, 2014, 08:28:17 pm »
     So what did you do different to increase it .41 mpg, not drive as fast ?
Re: MPG Pt.1
« Reply #174 on: August 10, 2014, 10:41:33 am »
Not real sure.  i probably did not sit in as much traffic.  Also i put a new tonneau on at about 1/4 tank.   i can't drive faster than say 55 because all my tires are either out of round and/or distorted (see other posts regarding tires.  i am working on this currently).
i may start a new mpg thread, pt.2 soon.  My goal is to get 20mpg.  i think it's possible.
Re: MPG Pt.1
« Reply #175 on: August 15, 2014, 02:11:34 pm »
286.4 miles / 17.183 gallons = 16.66 MPG
3.399 regular at Sunoco, $58.41 to fillup
Re: MPG Pt.1
« Reply #176 on: August 17, 2014, 03:29:33 pm »
301.9 miles / 17.025 gallons = 17.73 mpg
$3.389 per gallon regular at Exxon, $57.70 to fillup
This time virtually ALL highway miles, i even went 74ish for a while because i was late one time.  i also put a "new" tonneau cover on;  i will describe it in another thread.
Re: MPG Pt.1
« Reply #177 on: August 24, 2014, 06:56:34 pm »
260.7 miles / 16.740 gallons = 15.57 mpg
3.359 per gallon regular mobil   $56.23 to fillup.
Definitely more stop and go traffic.  i also want to say that for me and my personal situation i don't think not running a mechanical fan makes much a difference if any with mpg.
Re: MPG Pt.1
« Reply #178 on: August 26, 2014, 10:40:12 am »
291.3 miles / 17.76 gallons = 16.40 mpg
$3.329 per gallon regular at mobil $59.14 to fillup
Tonneau cover is currently off because i had to dump a lot of trash and now i need for the sun to really disinfect the bed.
« Last Edit: August 26, 2014, 10:42:14 am by Stewart G Griffin »
Re: MPG Pt.1
« Reply #179 on: September 05, 2014, 07:24:41 pm »
283.8 miles / 17.415 gallons = 16.29 mpg
$3.299 per gallon regular at Shell,  $ 57.45 to fillup
