Author Topic: Need help IDing this carb.  (Read 5592 times)
Offline award280
« on: May 21, 2008, 06:37:08 pm »
Hey gang.
I need some help figuring out what Holley I have here.  I've gotten the all the numbers that are stamped on the thing and the closest I could find was a 580 that was sold on the 66-67 Corvettes.  But when I got the rebuild kit for that carb, it turned out it wasn't for a matching carb.  If any of you guys could point me in the right direction so I can finally get this thing tuned.  If I slowly accelerate, it is fine, but it I get on it, it falls on its face.  I'm not sure if I'm running lean or rich or whatever.  Anyway, before I digress any further....
If any of you guys could tell me which adjustment screw is for the idle and which one is for the power circuit.
Offline Blue 82
Re: Need help IDing this carb.
« Reply #1 on: May 21, 2008, 08:31:20 pm »
It looks like a holley 4160
Upgraded with a quick change vacuum secondary spring housing
and 4 corner idle screws
it'a a single pumper
too bad the choke plate housing has been removed, all the info you nedd would have been located there
« Last Edit: May 22, 2008, 02:02:36 pm by Blue 82 »
Offline treny
    • 83C10
« Reply #2 on: May 22, 2008, 04:08:14 am »
I have one of them on my wagon its a 600 c0z I had a new kit put in it , thaught it was a 4160 but not sure Ide have to get the shop that did it and find out Ill call them today and see if they remember .. Bruce aka Treny
Hii There , Stating another project , an 83 c10 2wd  .Frame etc is all good and have to replace dash pad and seat , some body work and Paint Prob flat blk wth a clear cote to seal it.Ill keep in touch with updates ..Bruce
Offline ccz145a
« Reply #3 on: May 22, 2008, 08:14:03 am »
Yep, pretty sure it's a 4150. It's got the 2 metering blocks.
and a link... http://oldcarmanualproject.com/manuals/Carbs/Holley/TypicalViews/pages/4150.html
