Author Topic: ac swap  (Read 4497 times)
Offline 2502
ac swap
« on: May 22, 2008, 09:28:52 pm »
swapping ac and engine, tranny, etc over from an 80 to a 79. i got the dash out, got the duct work out, but have yet to tear into the 79 since the 80's a junker anyway. are all the ducts, etc in the same spots? i noticed one vent on the drivers side that's not in the non ac truck. does everything have to be swapped over or just that vent?
Offline HAULIN IT
Re: ac swap
« Reply #1 on: May 22, 2008, 11:07:50 pm »
You need to swap the entire unit. Under the dash: evaporator core-heater box case,ducts,control assembly,wiring, dash pad insert & gauge bezel.To complete the swap, the fresh air vents in the kick panels should be changed. Out under the hood: condenser,compressor,evaporator-heater case,hoses,vacuum ball & valve,ect. You will also need to remove a strip of firewall where the evap-heater box goes (look at the two firewalls once striped down & make a template) & drill a few holes. I'm sure I left out a few things, it's plenty doable, just keep track of everything & take your time. Lorne
Offline 2502
Re: ac swap
« Reply #2 on: May 25, 2008, 08:19:28 pm »
thanks... that's what i thought so i've been really careful taking everything out. i took out the duct work, and the controls, dash, gauges, etc but i left the wiring alone for now until someone that knows these better can help out. i don't wanna make the job harder for someone helping me out..
