Author Topic: '07 take offs on my 1985, I am pleased...  (Read 23798 times)
Offline Fordeatinz71
  • 78k miles and counting
Re: '07 take offs on my 1985, I am pleased...
« Reply #15 on: June 30, 2008, 05:18:17 pm »
BIIIG improvement!  personally i've always liked these myself...
that's my friend Matt's '91 Silverado...he's basically restored it since he got it at 16...he's 24 now...
Online zieg85
« Reply #16 on: June 30, 2008, 05:21:29 pm »
I agree, but finding the right "conversion lugs" for those rims are hard to find, at least when I looked, to use the bolt on centers
Offline biodiesel84
« Reply #17 on: June 30, 2008, 05:35:56 pm »
will the newer 20" wheels off a yukon fit on my 1/2 ton 5 lug truck or are the wheels 6 lug...I'm not sure...also if they are the right bolt pattern, do they have the right backspacing...
chuck.
Online zieg85
« Reply #18 on: June 30, 2008, 05:39:11 pm »
I believe they are all 6 lug now
Offline biodiesel84
« Reply #19 on: June 30, 2008, 05:41:39 pm »
thanks...:(
Chuck
Offline Dragon
« Reply #20 on: July 02, 2008, 02:13:47 am »
Chuck Don't get too discouraged there Bro! If you can afford the new Rims, you can easily pick up a set of adapters to make them work....  Since you have a 2wheeler, you can easily get away with running a set of the Correct 5 to 6 Lugger adapter plates(usually can be had for a couple of hundred give or take)....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline cptn60
« Reply #21 on: September 18, 2008, 04:36:26 pm »
I wonder if the newer wheels would work on a K20? Or is the center register small because of the IFS?
86 c10 shorty
Offline Dragon
« Reply #22 on: September 19, 2008, 01:44:27 am »
Ours would be a bit easier to match with the newer trucks, the biggest concern would be getting the correct Lugnuts for your truck to use them....  It's my understanding that the '88's to current went to Metric Lugs and Nuts, so one would need the SAE equivalent Nuts to work with whatever newer rim chosen(Atleast that is all the guys I have spoke to, did to use the Later '04 and up rims on their 73-80's).... :-X
I too am Hoping that is all I have to do, and I'll be picking up some 04's and up, to replace my Steelies when I get new tires(If I don't keep finding new problems with my truck, that was supposed to be "fixed" by the Shop that rebuilt it recently >:().....
Dragon
08 Magnum-New Toy
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #23 on: September 19, 2008, 08:54:57 pm »
The 8 lug wheels all swap out back to the mid sixties i think.  The offsets probably differ some, but the pattern and hub is the same for 8 luggers.  You need lug nuts with an outer thread for the center caps to attach to.  here's a set I found on ebay.  It's the same set I bought for my 78 with 2001 wheels.
http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__Wheel-Lug-Nuts-9-16-Dual-Thread-Chevy-GMC-32-Pcs_W0QQitemZ280267965775QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZViewItem?hash=item280267965775&_trkparms=72%3A543%7C39%3A1%7C65%3A12%7C240%3A1318&_trksid=p4506.c0.m245
