Body, Glass & Paint
Hood Hinges
Topic: Hood Hinges (Read 10070 times)
static22
Hood Hinges
May 29, 2008, 11:37:18 pm »
Can anyone tell me where to get a good set of hood hinges for a 77. I've tried a few different sources but have had no luck. Thanks for the help.
static22
Re: Hood Hinges
May 30, 2008, 12:23:21 am »
I think I should clarify. I've found some but the have not fit well at all. I have two sets that both fit differently. I have adjusted them as much as possible.
hotrod24
Re: Hood Hinges
May 30, 2008, 12:28:06 am »
how are they not fitting? i have a 78 and i got a new fender and i had a time getting it back right
1978 pontiac grand prix...
static22
Re: Hood Hinges
May 30, 2008, 12:35:23 am »
The old ones are "sprung" as they say. One set won't allow me to close the hood all the way. The other set is better but still won't pull the back of the hood down. It feels as if they are binding as well. I've got a set of hinges from an 80 something Buick where the hood opened forward and am thinking about trying to make them work. I've seen it done but can't remember where I saw it or how it was done.
hotrod24
Re: Hood Hinges
May 30, 2008, 12:45:23 am »
well the set from the buick i would not try but the 80s hinges you might need new springs or just get a brand new set but try this site it helped me but like i said you might just a new set
http://www.autobody101.com/articles/article.php?title=Body%20Panel%20Alignment
static22
Re: Hood Hinges
May 30, 2008, 08:49:49 pm »
The Buick hinges I saw on a mid 80's truck. He had modified them to allow his hood to open and tilt forward. It looked pretty cool and fairly simple. As for the new hinges I have tried two new sets with no luck on the fitment. I'm just looking for a company that sells a GOOD set.
hotrod24
Re: Hood Hinges
May 30, 2008, 08:58:51 pm »
well i have always like that tilt thing myself so if you want to do that go for it but you could try that site i gave you but if you do that tilt forward thing keep us updated and show pics
hotrod24
Re: Hood Hinges
May 30, 2008, 09:07:20 pm »
you need this and if you would post some pics of your hood so we can see it and try to help you out
http://store.gaugemagazine.com/index.asp?PageAction=VIEWPROD&ProdID=3659
Last Edit: May 30, 2008, 09:22:11 pm by hotrod24
static22
Re: Hood Hinges
May 30, 2008, 09:25:20 pm »
Thanks I'll check into them. Last time I saw those (year or more ago) I was told they wouldn't work on my 77 but they didn't say "universal" either. I'm not opposed to using a stock hinge but I've been dissappointed with the quality of the hinges Ive purchased.
hotrod24
Re: Hood Hinges
May 30, 2008, 09:31:41 pm »
where did you get the hinges
static22
Re: Hood Hinges
May 30, 2008, 09:47:32 pm »
Two different local aftermarket parts suppliers. I'm pretty sure they are not made in this country.
78 Chevyrado
Z62 ON-ROAD
Site Supporters
Re: Hood Hinges
May 30, 2008, 11:16:20 pm »
Classic parts of america. I just bought the left hinge for my 78 and It fit perfect. The hood closes properly and is a lot easier. I haven't been unhappy with anything I've gotten from them, from hinges to my grille to weatherstripping to my single key doorlock ignition cylinder set. Can't loose with them (so far...
static22
Re: Hood Hinges
Reply #12 on:
May 31, 2008, 12:41:21 am »
Thanks, I'll try them. As for the tilt hood, if I decide to try it I'll definitely post some pics and let you know how it goes.
Body, Glass & Paint
Hood Hinges
