Author Topic: clutch replacement  (Read 4719 times)
Offline arkoza63
clutch replacement
« on: May 30, 2008, 06:29:35 pm »
about how long does it take to replace a clutch and presser plate on a 82 c20 burb 2 wheel drive 350
gone crazy, be back soon
Offline HAULIN IT
Re: clutch replacement
« Reply #1 on: May 30, 2008, 07:53:50 pm »
That's a real general question there! A guy that has done many (a tranny guy or experienced hobbyist) could likely change it in about the time it would take you to eat a 12" meatball sandwich, me... most of a day! And that's if everything goes good.  Lorne
Offline DirtyLittleSecret
« Reply #2 on: June 02, 2008, 11:09:36 pm »
Obviously, you are better at it than I! :D
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
Offline 76 k10
« Reply #3 on: June 12, 2008, 01:12:27 am »
if you take your time and do it right and clean all the parts as you take them off :D it will take about 5 hours
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #4 on: June 12, 2008, 08:35:17 am »
on my first car, the old 68 mustang three speed, I burned so many tires and therefore clutches, that I could inspect the flywheel (turned if needed) replace the clutch disc, throwout bearing, pressure plate in about two hours blindfolded. The hardest part was lining up the disc to the flywheel....i ground down an old broom stick handle to use as a guide to line up the disc to the flywheel.
that's removing the driveshaft, cross member, shifter (three bolts), clutch linkage and spring,  trans (fout bolts), bellhousing (6 bolts), pressure plate (6 bolts).
Man she was always tight with a new disc---loved that old car.
