Author Topic: a/c - heater control  (Read 17165 times)
Offline comp
  • 76-77-78
« on: May 31, 2008, 06:01:07 pm »
is there a tech artical on them,,looked and couldn't find
Offline comp
  • 76-77-78
Re: a/c - heater control
« Reply #1 on: May 31, 2008, 09:23:11 pm »
OK has anybody worked on theirs ?????
« Reply #2 on: May 31, 2008, 10:36:33 pm »
I haven't had trouble with any. What problems are you having, and I bet one of the guys here will help, but we need to know the symptoms before we can know the cure.
Offline comp
  • 76-77-78
« Reply #3 on: May 31, 2008, 10:59:02 pm »
well for one changing fan speeds with the key on will blow a fuse sometimes,, and when you change the controls they don't always work
Offline okuma
« Reply #4 on: June 01, 2008, 12:36:23 am »
start  by changing out thr complete ac/heater panel on your dash....
     this panel contains electric and vacum components.
Offline comp
  • 76-77-78
« Reply #5 on: June 01, 2008, 07:15:16 am »
 i have three trucks and would like to save the $$$ and fix them
Offline okuma
« Reply #6 on: June 01, 2008, 12:40:57 pm »
i meant only the controls on thr dash....
if you have 3 trucks swap them from one to another one..
Offline comp
  • 76-77-78
« Reply #7 on: June 01, 2008, 01:55:07 pm »
all three have problems ,,,,, >:(
« Reply #8 on: June 02, 2008, 01:05:46 pm »
Blower fuses: I would check the wiring to the switch.  Is there an after market radio in the truck?
Controls:  Vacuum leak, or lack of.
Offline comp
  • 76-77-78
« Reply #9 on: June 02, 2008, 08:42:06 pm »
 no radios,,, doesn't seem to be any vac. leaks,(sprayed with starting fluid and no change)
Offline comp
  • 76-77-78
« Reply #10 on: June 18, 2008, 10:55:50 pm »
 bump ?
« Reply #11 on: June 19, 2008, 12:47:29 pm »
I don't know what to tell you on the fan other than start putting a meter to it to find where the load is coming from.
As for the controls, can you tell if anything is actually moving?
Offline comp
  • 76-77-78
« Reply #12 on: June 19, 2008, 12:52:41 pm »
 yes all is free ,,one is tight but i think that one is the cable  ???
