Author Topic: Decoded VIN  (Read 3549 times)
Offline acountryclipper
Decoded VIN
« on: June 03, 2008, 07:39:09 pm »
I just decoded the VIN on my 86 chevy 3/4 ton and the engine code says it has a 350 heavy duty. does the heavy duty mean that it has a 4 bolt main or what?
Re: Decoded VIN
« Reply #1 on: June 03, 2008, 11:34:18 pm »
It means it is the low emmissions model.  It "might" have 4bolt, might not...
Offline Fast68Chevy
  • I am THE Fast68Chevy!
Re: Decoded VIN
« Reply #2 on: June 22, 2008, 01:49:35 pm »
heavy duty emissions
normally is vin engine digit code M
bolt mains will be random
these usually had the TCC system with a relay mounted on the pass side valve cover, and virtually no other emissions equipment and no cat converters either, and commonly were equipped with factory dual pipes, 1 ton and some 3/4 ton pickups and vans both if are over the required GVWR
good luck :D
1967/68 C30 dually truck build frame up currently.  1975 C20 YE9 pickup longfleet 96K original miles DD.  and tractors and more trucks.
