Author Topic: Shaving the pinch weld seam  (Read 5890 times)
Offline Monzter
    • Monzter Kuztomz
« on: June 25, 2008, 01:00:21 am »
I'm looking at removing the pinch weld seam ( the seam at the bottom of the rockers ) on my Suburban, just not sure how I want to go about doing it. If anybody has done this I'd like hear how you did it, some pics would be awesome.
Offline HAULIN IT
Re: Shaving the pinch weld seam
« Reply #1 on: June 25, 2008, 09:32:34 am »
Monzter, That would be quite an undertaking, not impossible by any means, just a time consuming operation. The best way would be to cut about 1" wide areas every 6" or so & weld the spot (to hold the two panels together) then go back & cut off the rest & tack in the middle & finish welding it up. Have Fun! Lorne
