Author Topic: 6.2 turbo  (Read 26897 times)
Offline biodiesel84
6.2 turbo
« on: June 30, 2008, 11:48:12 pm »
what all do I need to convert a 6.2 to turbo...I want to go with all 6.5 turbo parts if possible...I already have the 6.5 turbo exhaust manifolds, so I hope they'll work...I just need to know what parts I need and what modifications to the engine I need like turning up the injection pump...thanks guys...
Chuck.
Offline DnStClr
Re: 6.2 turbo
« Reply #1 on: July 01, 2008, 01:34:49 am »
We haven't seen much info on diesels in this forum Chuck, but The 6.2 is  compatible with 6.5 parts ( same basic block) and the mechanical injection system is more reliable than the electronic sytem. You probably know the two sites
www.thediselpage
www.thedieselplace
 They will provide you with all kinds of info for your swap. Especially the archived threads from the diesel page. Good luck with it. I love my
Duramax and had thought about buying a  late 80's truck with the 6.2. They're getting hard to find..
Don
87 Chevy Silverado
Offline biodiesel84
Re: 6.2 turbo
« Reply #2 on: July 01, 2008, 09:46:37 am »
yeah I love my diesel...27 mpg isn't too rough on the wallet even at 4.55 a gallon...yeah I've looked at those pages briefly, but never thought to look at the archives...that's be my next stop...I figured I'd have more detailed info here because it's a site just for our trucks instead of on all gm diesel site, but I get what you're saying about there not being much info here about diesels...thanks again for the archive tip...
Chuck.
Re: 6.2 turbo
« Reply #3 on: July 01, 2008, 01:11:36 pm »
Yeah I keep trying to get more diesel guys over here, but the usually hang out at those listed sites.  So do run off :D bring the knowledge back.
Offline DnStClr
Re: 6.2 turbo
« Reply #4 on: July 01, 2008, 11:57:24 pm »
Getting more fuel to the engine should start with the basics- a bigger exhaust system and a better flowing air filter. And of course, a turbocharger. :D That engine doesn't have a cat on it does it? Gotta get rid of the cat to help airflow... Those mods will add more heat to the engine and may require a bigger radiator. But ya can't be faulted for trying to get more power out of the 6.2. They need some help. When the engine breathes better, it brings in more air. More air brings in more fuel, and increases power. Visious cycle. (There goes that 27mpg... probably clear down to 24mpg) You'll need gauges too to monitor egt temps and boost pressure.
 Here's a link to help turn up the fuel injector pump-
http://flashoffroad.com/Diesel/injectionpump/mechanicalpump.htm
« Last Edit: July 02, 2008, 12:00:22 am by DnStClr »
Don
87 Chevy Silverado
Offline Mr Diesel
  • Aaron
Re: 6.2 turbo
« Reply #5 on: July 07, 2008, 10:29:53 pm »
If you go with 6.5 system you will have to remove or modify your a/c housing, as the 6.5 system was not designed to fit in the 73-87 engine compartment.
gmdiesel.com has forums attended by guys who have done this swap, though. I recommend checking it out.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline biodiesel84
Re: 6.2 turbo
« Reply #6 on: July 07, 2008, 10:46:52 pm »
thank you for the link...
Chuck.
Offline biodiesel84
Re: 6.2 turbo
« Reply #7 on: July 07, 2008, 10:47:57 pm »
linky no worky...
Chuck
Offline Mr Diesel
  • Aaron
Re: 6.2 turbo
« Reply #8 on: July 08, 2008, 09:15:23 pm »
Offline biodiesel84
Re: 6.2 turbo
« Reply #9 on: July 09, 2008, 06:39:07 am »
thanks...
Chuck
Offline MajMike
  • Retired USAF Major, Disabled Vet
Re: 6.2 turbo
« Reply #10 on: July 23, 2014, 01:12:24 pm »
Chuck.
Here's what you need:
http://www.motortopia.com/dieselworld/tech/a-surplus-6-2l-blazer-gets-a-banks-sidewinder-turbo-kit-1754/
'82 K5 4wd Silverado w/ 6.2 diesel w/ Banks Turbo and rear disk conversion, J-code intake w/ EGR delete, more to come . . .
