Author Topic: body mounts 'groan' and squeak  (Read 6075 times)
Offline vince311
« on: July 01, 2008, 01:40:10 pm »
they appear to be stock originals....   whenever I'm going really really slow, and the body twists (like when pulling into a driveway)... i get some terrible squeaky/groan sounds that appear to originate from the body mounts.
is it just time to replace? or can i spray some kind of lubrication?
'82 Chevy shortwide, 2wd, 350/350 - Sold
Re: body mounts 'groan' and squeak
« Reply #1 on: July 01, 2008, 02:05:33 pm »
What do they look like?  If they are worn and sagging I would replace them.
Offline vince311
« Reply #2 on: July 01, 2008, 03:07:14 pm »
they aren't cracked....or appear to be sagging. but then again, i have nothing to them compare to. sounds like replacing them is the answer.
Offline hotrod24
« Reply #3 on: July 01, 2008, 03:25:02 pm »
here is mine thay need to be replaced it might do some good to spray some wd40 on them
1978 pontiac grand prix...
Offline 80stepsideguy
« Reply #4 on: July 03, 2008, 10:27:29 pm »
Not that hard to replace, if i were you i reccomend doing all 4 on the cab and do the 2 on the radiator support.that way the car doesnt sit higher then the radiator support.Check your front cab mounts also make sure your body mounts didnt fall thru if so then your gonna need to so some welding/replacing.
thanks
pat
1998 Chevy 1500 S/B 2wd
