Author Topic: Long tubes and purple hornies???  (Read 6541 times)
Offline melbatoast
« on: July 02, 2008, 08:00:52 am »
Whats up guys? First post, I just bought a 77 c10 and the exhuast is shot. I'm wanting to run some longtubes and bolt on purple hornies, or the cherry bomb header mufflers. Will the cross member be in the way? What issues might I run into?
Thanks for the help.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Long tubes and purple hornies???
« Reply #1 on: July 02, 2008, 01:13:47 pm »
are you talking about just bolting them glass packs to the headers and then maybe some turn downs? I dont think you will have any issues if its 2wd. It will resonate you to death though  :P
Offline melbatoast
« Reply #2 on: July 02, 2008, 02:06:54 pm »
The sound won't be an issue, you should hear it now  :-[
Yeah the glasspacks with a flange that bolts to the collector...
I hope they fit.  ;D
« Reply #3 on: July 02, 2008, 02:20:04 pm »
Are you lowered any?
Generally the longtubes that are for 73-87 applications make it so the header points to the ground, so the glasspack is just going to be that much closer...
Offline lowriderbowtie
« Reply #4 on: July 02, 2008, 03:14:28 pm »
should work good.  similar to what I have on my truck.  Ive got long tubes 2.5" pipe with a crossover and dynomax bullets dumped right before the axle.
Id like to run some pipes over the axle and out both sides eventually.  I think it would sound alot meaner
1976 3/4T Camper Special
350, LT headers, H pipe, Dynomax bullets, 4/3 drop
Offline melbatoast
« Reply #5 on: July 02, 2008, 03:18:42 pm »
Well crap, I was gonna do a 4/5 drop on it. Oh well maybe I'll run that setup until I get the truck to where I don't mind spending the money on a full exhaust.
