Author Topic: Backup lights  (Read 6637 times)
Offline gbskunk2006
Backup lights
« on: July 05, 2008, 12:43:48 pm »
86 GMC C1500
I've noticed that if I "jiggle" the shifter while in Reverse that my backup lights work.  There is some play with the shifter which I would expect.
Is the neutral\backup switch adjustable or does this mean I just need to replace the n\b switch with new?
Thx in advance.
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Offline Prong
Re: Backup lights
« Reply #1 on: July 05, 2008, 02:17:59 pm »
There should be some adjustment in that switch so that you won't have to jiggle the shifter. There's two screws where it attaches to the column are what you're wanting to look for to make your adjustment.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
