73-87 Chevy & GMC Trucks
pinch weld on firewall
Topic: pinch weld on firewall (Read 15456 times)
gerardo0367
hi all
July 08, 2008, 12:34:35 am »
Has anyone removed the pinchwelds from the firewall if so do you have any pics or pointers please
All Man wheres my wallet and my keys I wont try that again
HAULIN IT
Re: pinch weld on firewall
July 08, 2008, 08:18:35 am »
Gerardo, The firewall pinchweld could be removed in the same manor as others. The best way I've found is to use, say an electric grinder with a wide grinding disk & notch slots (between the spotwelds) every 6" or so. Starting at the outer edge, go in until the layers are flush with where you want to end up. Now make a tack in each notch, go back a cut off the pinchweld & grind flush, tack in between each 6" area, then weld the seam up. Closing up the seam can be time consuming, especially if there is different thicknesses of metal or rust between them. Go slow & move around, with the lip gone the panels will have a little more of a tendency to warp. Have Fun, Lorne
July 08, 2008, 10:21:14 am »
There is a lot of structural support/bracing at that point if you are talking about where the floor pan meets the firewall.
Blazin
Blazin new trails!
July 08, 2008, 11:48:39 am »
Why would you want to remove it?
gerardo0367
hi all
July 08, 2008, 10:40:25 pm »
They are the ones right above the blower motor and above the harnesses connector i want to remove them for a clean firewall look i want it as smooth as possible
July 09, 2008, 10:55:44 am »
Oh, higher up where the cowl meets the firewall.
gerardo0367
hi all
July 10, 2008, 12:08:39 am »
Yes that's right i would like to see some pics if possile if anybody has any
SUX2BU99
July 10, 2008, 11:53:00 am »
Sorry to butt in, but how smooth is that supposed to be from the factory? Mine is quite bumpy and I don't want to think it was because of painted over rust or something. When I push on it, it doesn't feel soft.
July 10, 2008, 11:58:08 am »
here is a pic I have saved of one...
SUX2BU99
July 10, 2008, 12:33:47 pm »
That doesn't exactly look like that came from the factory that way lol I'll upload a pic I have showing what mine looks like. You can clearly see the seam along the firewall where the upper meets the lower and it's bumpy in texture.
July 10, 2008, 02:09:14 pm »
That is a pic of a smoothed one with the pinch welds shaved along with the rest of the firewall.
Factory, you can see the seam along with the "Gunk" sprayed on the firewall to seal it.
This is what one looks like if you clean everything off:
gerardo0367
hi all
July 11, 2008, 12:45:49 am »
The red truck looks like what i want to do to mine what was done to get it that smooth i want to keep the heater box and the wiper motor ?
HAULIN IT
July 11, 2008, 07:57:27 am »
Gerardo, What you do is ... Cut & weld the pinchwelds, weld up all of the seams & holes for the wiring, screws, plugs, ect. Cover pretty much all of the firewall with bodyfiller & sand smooth. Prime & paint. Re-route wiring, ground connections, ect. to hide them from view. Have Fun grinding & sanding! Lorne
Bitzer!
Smiles per gallon
July 13, 2008, 06:21:14 am »
The red one sure looks kewl
Unfortunately I have neither the time or inclination!!
1979 GMC CrewCab C20 1t
