Author Topic: sliding glass window  (Read 5024 times)
Offline hotrod24
« on: July 10, 2008, 12:00:15 pm »
ok i have tryed to put my window back in but it want go in so how do i use the string? and where do i start i was using a screw driver to do it and that did not work.
1978 pontiac grand prix...
Re: sliding glass window
« Reply #1 on: July 10, 2008, 12:08:17 pm »
Wrap the seal around the window, set the bottom on top of the opening and seat the seal, push it up to the window and get the corners in.  Wrap the rope from one side to the other, have someone on the outside push it in and pull on the rope.
Offline hotrod24
« Reply #2 on: July 10, 2008, 12:19:06 pm »
thank you
« Last Edit: July 14, 2008, 09:31:14 pm by hotrod24 »
Offline hotrod24
« Reply #3 on: July 14, 2008, 09:30:49 pm »
ok i been working on the rust for the window but i can not get in the corners with nothing what would be a good thing to use could i use a sand blaster
« Last Edit: July 15, 2008, 04:12:44 pm by hotrod24 »
Offline hotrod24
« Reply #4 on: July 15, 2008, 10:59:25 pm »
« Reply #5 on: July 16, 2008, 10:50:29 am »
that will remove it!
