Author Topic: doors hang  (Read 4497 times)
Offline the_legend_1981
doors hang
« on: July 18, 2008, 05:04:28 pm »
Both of my doors hang a little low in the rear. Should i adjust the hinges or do i need new ones?
Offline joesgarage71
  • Wrench
Re: doors hang
« Reply #1 on: July 18, 2008, 05:49:13 pm »
Bushings on the top hinge need to be replaced. Common on these trucks.
Re: doors hang
« Reply #2 on: July 18, 2008, 06:39:13 pm »
how do you go about changing these? Where can you find the bushings?
  • Wrench
Re: doors hang
« Reply #3 on: July 18, 2008, 09:20:04 pm »
 The top hinge pin is staked you have to remove the door to work on the hinge, leave the hinge bolted to the cab, to get the pin out either grind the bottom of the pin off or cut the bottom off with a cut off wheel.Don't tear up the hinge ginding. Replace the pin and the bushings from the kit. A hinge kit can be had at your local parts store.
« Last Edit: July 18, 2008, 09:43:15 pm by joesgarage71 »
