Author Topic: Cold.Is a bad thing..  (Read 4124 times)
Offline Redneckchevy
    • Photo Bucket
« on: February 07, 2007, 01:39:00 pm »
Well went out side the other day ....It was 22 below 0 here in northeast ohio...Anyways i got in my truck and Pushed in the clutch...No problume ..Turned the Key..My engine would barly turn over..SO i waited a sec..Tryed it again..Saw Smoke coming out of my hood..and thure my hood scoop plug...The rubber burned completley off the Ground cables And my batter was swollen looking..So
$100 later i was good to go ..I upgraded All the battery cables frome 4gauge to 2 gauge..And replaced my battery with a lil bigger one that had alot more cranking amps
Offline roundedline
Re: Cold.Is a bad thing..
« Reply #1 on: February 07, 2007, 04:48:00 pm »
hope you focused on COLD cranking amps when you got the new one....
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: February 07, 2007, 05:42:00 pm »
I am sure you were not the only one with battery problems during this cold snap.  All battery companies and auto stores are smiling big right now due to the business they are getting.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
« Reply #3 on: February 07, 2007, 09:11:00 pm »
I had to jump start my sander this morning, it would crank but just not quite fast enough.
