Author Topic: 73-80 to 81-87 Frontend conversion by Monzter  (Read 65747 times)
« on: August 04, 2008, 10:07:03 am »
Well I just swapped my 73 Suburbans clip out for a front clip of a 86 Chevy truck. I thought that some people might like to what it takes to do this, everything I found on line did not show what it takes so I took pictures of my swap.
The unsuspecting Suburban.
The 73 front clip pulled off.
The plastic screen, weather strip & wiper mechanisms need to be removed now.
Now time to mark out where the cutting for new hood hinge holes & bolts need to be.
Here's where I had to add metal for the hood hinges, I added some support also, it seemed a little flimsy without it.
Test fitting the hinges.
With rubber.
Now it's time to drill holes for the wiper mechanisms, plastic screen & cowl. I forgot to take pictures of the drivers side wiper mechanism hole, it had to be enlarged to fit the longer mechanism.
After hoes drilled in the right spots I installed the cowl.
Next is to put the clip on.
Here you can see where I had to enlarge some of the holes to get the clip lined up.
Now the fenders are shimmed & bolted down.
Next is the hood. I drilled a hole in the firewall & used a new hood release cable to be able to open the hood.
The front body mounts had to be cut off & welded on in the right place along with cutting the frame for the bumper.
Drilling holes for bumper.
Ta Da! It's all on.
Next is to wire up the headlights & turn signals. I kept the wiring harness from the old clip top do this, the bulkhead connector is way different & wires will need to be spliced. I did no get pictures of this, it's not that hard to do though if you can do this clip swap.
Re: 73-80 to 81-87 Frontend conversion by Monzter
« Reply #1 on: May 15, 2011, 12:09:57 pm »
Hinge location/size detail:
« Last Edit: May 15, 2011, 12:13:36 pm by Captkaos »
